OtterTech wrote: ↑Tue Apr 21, 2026 3:59 pm
Yes they are generic default. I assumed that they would work as a starting point for further tuning.
The best thing about the OI control board is you have control of every parameter. The worst thing about the OI control board is you have control of every parameter.
Its always good to start with a known set of parameters for that specific inverter/motor combination, if its available. There are plenty of parameters that are set-and-forget, that are the EV equivalent of telling an ECU "how many cylinders" or "displacement" or "cam profile", which may be very different between different inverters. You might get motion if they're wrong, but you won't get a good result.
The ones Johannes shared are a good starting point. I've also attached my old base tune. I've got to pull a more recent one off my workshop laptop at some point, but this one was a pretty good street tune with a base LDU.
