Unlocking the power/torque of Prius gen 3 drive train?
Ghia66
Has thanked: 749 times
Been thanked: 65 times
Re: Unlocking the power/torque of Prius gen 3 drive train?
Post by Ghia66 »
Thanks, great information!
I am waiting to see how the Prius power comes along until I change to custom axles.
Ghia66
Post by Ghia66 »
Welded up and ready for action!
As Greg said “Two Post Lift in the free range, open air, organic garage setting with liquid cooling”
Not pleasant in the workplace today!
Ghia66
Post by Ghia66 »
tom91 wrote: Fri Jan 30, 2026 5:13 pm So all data + Power Calcualted in kW
Now just kW + Potnom on left and speed on right.
Notice how we reach a steady state power even though potnom is flat.
The steady state of around 25-27kW is a clue. I will review some of the HTM code for the toyota prius once I have moved house. Busy moving this weekend until next one. Maybe during the week I got a few minutes, all be it without internet at my new house :(
Hi Tom, hope the house move went okay.
Wondering if you have had a chance to look at the HTM code and have something for me to test out?
The car is running seamlessly 🙂
Ghia66
Post by Ghia66 »
So in an attempt to run down the 12 kWh BMW pack a bit (starting at 342) before my next granny charge I went for a drive.
Did a few runs with accelerator flat to the floor and then regen when I caught up to the car in front.
log (15).csv
(5.3 KiB) Downloaded 3 times
Has thanked: 328 times
Been thanked: 847 times
Ghia66 wrote: Thu Feb 19, 2026 5:56 pm Hi Tom, hope the house move went okay.
No not had time to look at code yet, still got plenty boxes to go through. Does not help I work full time.
Ghia66
Post by Ghia66 »
Thanks Tom, totally understand 🙂
Ghia66
Post by Ghia66 »
Would like some advice on how to reduce the juddering that happens when coming off regen at slow speed and getting back on the accelerator to keep rolling.
It really only happens at slow speeds.
Are there any tweaks to Parameters that may help?
Ps I have a video to show the juddering but can’t seem to upload it!
There is a current issue that other have that is the same that gets fixed by removing a feedback value to the Lexus inverter it may also fix on the Toyota.
Ghia66
Post by Ghia66 »
That sounds very interesting 🙂 Is it available on the forum?
No yet fully verified thats why its not released at the moment.
Let me review the Prius code and I can spin you a test version to try
Reviewed code, already 0 in prius and is300h code.
Ghia66
Post by Ghia66 »
Bigpie wrote: Wed Jan 28, 2026 7:46 pm A good way to get logs is to use the can map to broadcast data and use savvycan to record
Jamie how do I use a can map to broadcast data now that I have SaavyCan working and taps on Canbus for BMW Sbox and Outlander charger?
Ghia66
Post by Ghia66 »
Okay, I’m now ready to GPS record up to 200 kph now!
Bonus, it has an Odometer function as well.
Ghia66
Post by Ghia66 »
Drive to the first VW meeting of the year a 50KM round trip and the car ran flawlessly!
The Garda paid us a visit in their electric VW!
I have discovered that if I feed the power through lighter application of the accelerator the car will go faster (over 120kpm) than if I plant the accelerator pedal to the floor. When I plant the accelerator to the floor it feels like the car hits the wall at about 104kmh.
Have logs for the foot to the floor/ hit the wall drive.
Should I find a long clear road and see how fast it goes and log this?
marcexec
Has thanked: 1039 times
Been thanked: 111 times
Post by marcexec »
Ghia66 wrote: Mon Apr 06, 2026 11:37 am
For science? I'd say solve the brick wall issue first, though.
My Suzuki RF400 build @ES
Honda IMA & Lebowski howto
Ghia66
Post by Ghia66 »
For science… obviously!! 🙂
Ghia66
Post by Ghia66 »
Went for a drive and got to 130kph ish in traffic. Tried driving accelerator flat to the floor and then feeding in the accelerator when rolling.
log (33).csv
(5.83 KiB) Downloaded 2 times
log (31).csv
(5.83 KiB) Not downloaded yet
log (32).csv
(5.83 KiB) Downloaded 1 time
Ghia66
Post by Ghia66 »
The updated brown book arrived from the Department of Motor Taxation today.
Interesting that it says my engine capacity is 1285 cc!
Ghia66
Post by Ghia66 »
Hi Tom, does this part of the code have something to do with the Gen 3 power/speed limit issue? 🙂
This code has been played with in greg vw rabbit/golf. with no impacts.
I need to still have a look at your logs. Work is keeping me too busy to have any mental capacity left in evening to do coding.
Ghia66
Post by Ghia66 »
Thanks Tom, totally understand! 🙂
