Can someone explain how I can implement a (2000psi, 0.5 - 4.5v) brake line pressure sensor to increase regen in parallel to brake force, in the zombieverter.
How- regen control with pressure sensor
- Has thanked: 166 times
- Been thanked: 411 times
Re: How- regen control with pressure sensor
Why complicate with pressure? You could use linear pot 5K to return 0V to 5V signal. You put this under your brake pedal together with brake switch.
Then you can program zombie with your selection of curve...
https://uk.farnell.com/tt-lm10-potentiometer
https://www.aliexpress.com/i/1005006263163326.html
- Has thanked: 328 times
- Been thanked: 847 times
Zombie only does an on off brake sensor. There is no Analogue input for brake position thus regen request mapping.
Regen level change is only done on speed.
CapriV
- Has thanked: 43 times
- Been thanked: 27 times
True. Could do it that way too, but it seems this is a no go feature anyways. Thanks!arber333 wrote: ↑Fri Apr 10, 2026 9:34 pm Why complicate with pressure? You could use linear pot 5K to return 0V to 5V signal. You put this under your brake pedal together with brake switch.
