I'm planning an EV conversion of my VW LT28 Florida (Westfalia campervan). The last 4 years I have been travelling full-time with this vehicle and i love everything about this old camper -- but the engine.. In the next couple of months i hope i can change this.
The idea for the conversion is ripening since a couple of years now, the main reasons why i now decided to pull the trigger are the following:
- I am a very slow traveller: My current travel profile is ~ 7000 km / year, mostly in short trips (max 200 km, often shorter) with longer stays (3-4 days) in between, which makes charging at 220V hookups e.g at campsites feasible. Also, being a camper brings interesting opportunities like solar trickle charging (there is space for ~1kW of solar panels on the roof and one might get creative for adding more panels).
- The current diesel engine is generally a reliable workhorse, but it slowly shows its age. Especially at higher elevations and in coldish weather conditions it struggles to start and provide enough power and torque. Even as I do not want to travel to winter destinations - in the last years i always rented a place from december to february in whichever country i was and stayed stationary - but in the mountains of Turkey or Georgia i definitely found the limit of the current engine (at an outside temperature of ~ 0-5 C and elevation of 2000+ m). With the perspcetive of more overlanding trips to central Asia in the future i need a drivetrain that handles these conditions better.
- The LT28 platform can be upgraded to a gross vehicle weight of 3,500 kg by using compatible suspension parts of the LT35, which allows larger battery pack.
- My wife and i are journalists and photographers, so documenting the conversion and the travel with the converted campervan is a great opportunity to share our experiences and inspire others
I am aiming for a budget of ~15k EUR. Here's an overview of my current plan:
The Vehicle
- VW LT28 Florida (Westfalia campervan)
- Current engine: Diesel, 55 kW (engine code DW)
- Curb weight: 2,500 kg / GVW: 3,000 kg
- Travel-ready weight: ~2,800 kg
- Can be upgraded to 3,500 kg GVW with LT35 suspension parts
Project Goals
- Uprate GVW to ~3,500 kg
- Range: 250+ km under real-world conditions
- Cruising speed: 80 km/h, top speed: ~100 km/h
- Solar trickle charging capability
Drivetrain
- Nissan Leaf stack
- Zombieverter
- Motor mounted at original engine position, mated to the existing gearbox via adapter plate
- Driveshaft and rear axle remain unchanged
Battery
- Chemistry: LiFePO₄, mainly because it's considered more safe -- we do sleep in the van.
- Prismatic Cells: 230 Ah or 324 Ah depending on approved GVW
- Voltage: 300 V (96s) or 360 V (112s) - has anybody done the Leaf-stack with 96s LiFePO cells?
- Capacity: ~83–112 kWh
- Boxes: left and right of the driveshaft there are two ~ 1,200 × 600 × 250 mm spaces within the ladder frame, 1 more in the engine bay if needed.
- BMS: Flying ADC 16-channel modules
- Thermal Management: Heating pads for really cold weather, passive cooling for now.
Charging
- AC Type 2: 6.6 kW (single phase, 32 A) via Leaf PDU
- DC: CHAdeMO via Leaf PDU ?
- CCS: CHAdeMO adapter or Foccci - have to investigate more.
- Solar trickle charging (12 V aux battery --> 230 V inverter --> AC charger)
Weight & Uprating
- Estimated net weight gain: ~550 kg (removing ~300 kg diesel components, adding ~850 kg EV components)
- Front axle: re-registration from 1500 kg to 1650 kg already prepared with reinforced springs and shock absorbers
- Rear axle: LT35 leaf springs (2+1) already upgraded from original 1+1 LT28 Springs, possibly upgrading to 3+1 or 4+1 for an increase from 1600 kg to 1950 kg.
Brakes
- Bosch iBooster
Next steps:
- I am currently looking for a TÜV inspector that a) approves the GVW increase and b) has experience with EV conversions - any recommendatiotions in the area around Berlin/Brandenburg?
- I have to make a final decision for the battery. I really like the idea of LFP chemistry. So far i am planning on buying prismatic cells from NKON.nl or similar, though i am open to reusing modules or packs from other EVs. But havent really found the right ones that give me a total capacity of > 80 kWh.
I'll be documenting the build as I go.
