Only getting pull down ground on precharge relay and not on main or negative
Topics relating to the ZombieVerter VCU
manj3000
Post by manj3000 »
Hi all me again been racking my brains and have gone over and over this and still having issues. 2017 leaf stack and battery
So I did continuity test on all cables going from ZV to contactors and all other wiring. All wired up as the picture attached.
When I flick precharge I'm only getting power to the precharge relay and not to the negative or positive contactor.
Now I didn't wire this up to start with but went over all the wiring and I did find that the relay ground pin 32 was getting 12v + so I rewired that so it was getting the relay ground. But having this issue.
Batteries are all wired up and I'm getting 390v to the ccontactors.
Anybody have any ideas as what is going on, prams, spot values all attached
params.json
(2.15 KiB) Downloaded 7 times
spot2.pdf
(151.34 KiB) Downloaded 7 times
spot1.pdf
(166.78 KiB) Downloaded 8 times
spot.pdf
(160.01 KiB) Downloaded 9 times
Has thanked: 330 times
Been thanked: 848 times
Re: Only getting pull down ground on precharge relay and not on main or negative
You can try and move to the (Pin 3 right above Pin 31 that is used now) Out3Func/GP Out 3 pin and change Out3Func to Negative Contactor.
This way you can rule out a broken output stage.
manj3000
Post by manj3000 »
I will give that a try. Thanks
alucas
Has thanked: 4 times
Post by alucas »
Hello I missed your post in the General section. I have a similar issue and I posted in the Vehicle Control (VCU) section. https://openinverter.org/forum/viewtopi ... 313#p90313
Looks like I need to open up the VCU box and measure the pins and check the output drivers.
Aaron
