I just tested the Foccci with 12v, gnd and wake. There are some led lights and it looks alive. I connected CAN H/L to The ESP board that it came with and it says "communication problem between ESP and STM" i have CAN terminated on both devices.
There was a wiring issue and also the node was not set correctly so user error. double checking the test cable setup and setting node to 22 solved it. Now it works fine and i can see the parameters etc.
Develop a QCA7000 board?
- JaniK
- Has thanked: 101 times
- Been thanked: 15 times
Re: Develop a QCA7000 board?
