outlandnish wrote: ↑Fri Nov 14, 2025 6:31 pm
I'll get the current sensor block modeled this weekend. I pulled out one of them temp sensors from the original board and think it's pretty doable to make a 3D print. Damien, do you want a setup that matches the OEMs as close as possible or something we can adapt to the currently selected temp sensors?
I'll be working on the current sensor housing design, the temp sensor mentioned above has me confused though. Is the temp sensor part of the current sensor housing or a separate piece that needs something to be modeled? I looked in the wiki and found B57164K0473J000 but haven't figured out what's what yet.
r1ckyb0nd dropped off his 980 inverter yesterday. I'll be referencing parts from that, but haven't dug into it yet.
I also found this for the toroid search,
I'll try to use this to figure out a part number and see if there's anything off the shelf available. I'll make a stock current sensor housing and I'll consider doing a modified version if theres something else close size wise that works properly for current sensing.
Sounds like I may need to destroy the current sensor housing to get the toroid out to measure it. if someone has a toroid out or one in a broken housing and can share accurate toroid measurements it would help me work through this piece.
My goal is to give Damien the option to sell a 3D printed current sensor housing, toroids, and current sensors all assembled with his board.
