wanted: a few cells from the rear stack of a 2016 leaf 30 kwh
wjdijkstra
Post by wjdijkstra »
I have a pack with 1 extremely bad cell and a few pretty degraded ones, to get this car drivable again I would like to replace these cells first before I find the budget for an entire pack switch. So 4 cells or 2 modules needed :)
I'm from the Netherlands by the way.
headline
Re: wanted: a few cells from the rear stack of a 2016 leaf 30 kwh
Post by headline »
Hi! Did you get hold of cells? I’m looking for a 30kWh cell replacement since one of the cells in a module is bad (isolation fault).
From where did you get, any contact to recommend or du you have any to sell?
I’m located in Sweden.
Thanks!
