Unlocking the power/torque of Prius gen 3 drive train?
Ghia66
Has thanked: 750 times
Been thanked: 65 times
Re: Unlocking the power/torque of Prius gen 3 drive train?
Post by Ghia66 »
tom91 wrote: Thu Jan 08, 2026 6:43 pm Is all the 12V to the inverter via that relay?
If the issues remains like it does need to confirm what inverter Greg has in his rabbit and what firmware was used as a base for testing on it (yes I did write it but its a while ago).
Yes all the 12 volts is via the relay to the inverter.
The two inverters
Greg thinks that it was either version 2.17 or 2.19 with a in between custom release that you sorted out for him.
Thanks Tom
Ghia66
Post by Ghia66 »
I sent 2.20A logs and parameters to perplexity.ai to see what advice could be had.
This is what I got…
Is any of it worth trying/following up on?
With a Prius Gen3 inverter and BMW safety box, the fact it ran on 2.15A but not on 2.20A almost certainly points to a configuration / input‑mapping change rather than a hardware fault.​​
What is already working
The logs show opmode reaches 1, DC bus is ~362 V, and the inverter status is on, so the Prius inverter is actually being started by the VCU.
potnom reaches ~100% and dir flips correctly, so the throttle pedal and direction inputs are being read and scaled.
Motor speed changes slightly, so the inverter is producing some torque, just nowhere near enough to move the car.
This means the basic Prius inverter wiring, BMW safety box, and HV contactor control are OK.
Prius‑specific trouble spots with 2.20A
For a Prius + BMW safety box setup, these are the areas most likely to have changed between 2.15A and 2.20A and silently kill torque:
Drive‑enable / HV request input
If you use a 12 V “drive enable” (from the BMW box or ignition) into one of the generic inputs (e.g. HV request, park/drive, brake), confirm that:
The input is still mapped to the same function (HVReq, DriveEnable, etc.).
It actually shows the expected state in the web UI while your foot is on the pedal.
2.20A has slightly stricter logic in some builds: if that input is not in the “drive” state, it will let the inverter run but clamp torque to almost zero.
BMS / shunt configuration and limits
With a BMW safety box, the pack voltage/current may come either from a shunt, BMS over CAN, or be “fixed”. Check that:
ShuntType and BMS_Mode match what you physically have (for a simple BMW box without CAN current, often this wants to be “no shunt / simple BMS”).
CCS_ILim, CCS_SOCLim, SOCFC, BMS_VminLimit/BMS_VmaxLimit and BMS_TminLimit/BMS_TmaxLimit are reasonable so the VCU does not think the pack is out of range.
If 2.20A now expects current or SOC from a different source than 2.15A, it can decide “no valid current / SOC” and reduce traction torque.
Prius “gear” / direction handling
On the Prius connections, there is usually one “direction” line into the inverter and an optional “gear” input or logic inside the VCU.
Check that your dirmode and Gear / GearLvr settings are still consistent with your wiring (for example: forward when your BMW shifter is in D, reverse in R).
If the firmware believes it is in neutral or in a disabled direction state, you will again see potnom move but almost no torque.
Has thanked: 328 times
Been thanked: 847 times
Nope none of this has impact the code reports a torque so that will be sent to the prius inverter.
The issue possibly is in the start up method for the prius Gen 3 inverter. I would not expect this to be released without testing though so no idea why its an issue for you and not others. I believe my changes that Greg tested stayed into V2.20 and beyond.
Ghia66
Post by Ghia66 »
tom91 wrote: Fri Jan 09, 2026 8:14 pm Nope none of this has impact the code reports a torque so that will be sent to the prius inverter.
Thanks, Greg suggested that I check if my HSDN wire from the inverter is connected to, he thinks it goes to the Park signal from the transmission safety neutral.
How would I go about checking this out?
Ghia66
Post by Ghia66 »
It’s quite nippy in the “workshop” today!
Ghia66
Post by Ghia66 »
Well I’m back on the road after ST linking back to 2.15A and uploading the old parameters 🙂
Please try version 2.17 https://github.com/damienmaguire/Stm32- ... /tag/2.17A
I can spin you a "testing version" that reverts one change made between V2.17A and V2.20A just to review if that helps.
Since you can now use an ST-Link it makes this easier to do without bricking your Zombie.
Ghia66
Post by Ghia66 »
Thanks Tom, I will try 2.17A after I charge up my battery pack and revert back! 🙂
Ghia66
Post by Ghia66 »
Ghia66
Post by Ghia66 »
So I upgraded to 2.17A and it showed up in spot values as 2.20A!
Selected Prius 3 and restarted Zombie.
Selected manual and BMW Sbox… looked like it wanted to run but doesn’t
move.
params (3).json
(2.14 KiB) Downloaded 2 times
log (5).csv
(4.58 KiB) Downloaded 2 times
Please try flashing V2.17 with the ST-Link
Ghia66
Post by Ghia66 »
Will do, thanks Tom
Ghia66
Post by Ghia66 »
Used the hex file and uploaded 2.17A.
Changed parameters;
auto to manual, BMW Sbox, Prius 3
It moves! 🙂
Will go for a drive later and get some logs
Okay let me know how you get on. If it drives as it should I will revert the Prius specific changes in a test branch of the V2.30A release for you to test.
Ghia66
Post by Ghia66 »
Thanks Tom.
The car drove well…new top GPS speed 114kph!
Have attached logs and parameters.
log (6).csv
(2.42 KiB) Downloaded 4 times
params (4).json
(1.96 KiB) Downloaded 4 times
Ghia66
Post by Ghia66 »
Went for a short drive just using MG2 “doing a Greg” and the acceleration seemed similar, less regen didn’t have enough available road to see how fast it would go.
log MG2 A (1).csv
(2.75 KiB) Downloaded 4 times
Your logs are very short so not alot to see beyond you can drive it and command torque.
I will attempt to spin you a special version to remove the V2.20A release changes for the prius and send you a DM about it.
Ghia66
Post by Ghia66 »
Thanks very much Tom.
Are there a setting/s to make the log recording longer?
The log screen looks longer when I’m driving but when I stop logging and save they are short.
Look forward to the special version of 2.20A
Ghia66 wrote: Wed Jan 14, 2026 7:05 pm Are there a setting/s to make the log recording longer?
Not sure some of your previous logs were longers, have a look at the attached file sizes.
I have sent you a DM with the files.
Ghia66
Post by Ghia66 »
Thank you.
I will look at the older logs
Ghia66
Post by Ghia66 »
Hi Tom, got the bin file but it didn’t upload so I’m going to have to ST link.
Would you please resend the hex file as I couldn’t find it?
Ghia66
Post by Ghia66 »
tom91 wrote: Wed Jan 14, 2026 7:26 pm Not sure some of your previous logs were longers, have a look at the attached file sizes.
Went for a drive on V2.17A and plotted this 🙂
Ghia66
Post by Ghia66 »
Hi Tom, will you please resend the V 2.32.TA HEX file as I don’t seem to be able to find it and I’m bricked again?
Cheers Les
Ghia66
Post by Ghia66 »
Installed and changed parameters Prius G3 and BMW Sbox.
It works! Thanks Tom you are a genius!
It’s raining and my windscreen wipers are not working so it will be tomorrow before I go for a test drive.
Ghia66
Post by Ghia66 »
Well I just had to try it out so went to the shops in the rain and traffic.
Drove well…maybe smoother but suddenly noticed that I have very little/none regen! Lucky I fitted 4 pot Wilwood brakes!
log (6) 2.csv
(2.16 KiB) Downloaded 3 times
params (4) 2.json
(2.14 KiB) Downloaded 4 times
