Stealth EV Tesla Performance Large Drive Unit Kit (LDU)
ekohn04
Been thanked: 22 times
Post by ekohn04 »
$4500
Hi, I have a Stealth EV Performance LDU for sale in the California Bay Area. Below is the description, as well as pictures. I have the receipt from Stealth EV. Please message me with any questions.
This is a fully refreshed and serviced Performance LDU, including all the hardware needed to install the motor into an EV conversion.
Kit Includes:
-Tesla LDU
-Throttle Pedal (With Plugs & Pins)
-Brake Pedal Switch
-GV200 HV Main Contactor
-HV Traction Pack Fuse & Holder
-Pre-Charge Resistor
-Pre-Charge Relay
-Pre-Charge Fuse (5A) & USM1 Fuse Holder
-HV Cables For The Drive Unit (2′ Length)
-Tesla Water Pump (With Plugs & Pins)
-Brake Pressure Transducer (With Plugs & Pins)
-Direction Switch
-Shunt
-2x Tesla Contactors
-Rubber Coolant Line
-Coolant Temperature Sensor
-New Axle Seals
-Oil Changed (Shipped Full)
-Labeled 16′ Main Wiring Harness
