Hyundai Kona won't start just turns on but will not go on drive.
Fuzz
Has thanked: 14 times
Re: Hyundai Kona won't start just turns on but will not go on drive.
Post by Fuzz »
Hi
We drive on the same side as UK and Australia. The steering wheel is on the right side
Fuzz
Post by Fuzz »
Hi
I forgot to ask a very important question. Would normal scanners like launch and autel work on this car ? Or the gateway causes issues? I disconnected the wiring harness from the door. Can't see any crushed or damaged cables
Pelland
Has thanked: 11 times
Been thanked: 20 times
Post by Pelland »
Your mileage might vary.
The (very) budget tools I tried didn't work for me so I purchased ScanDoc. It works great on the OBD port but does complain occasionally about "anti theft device detected".
Project Gus has had good results using OBDLink LX dongle and an android app. See viewtopic.php?p=78617#p78617
Any modern professional grade scanner should give acceptable results.
Fuzz
Post by Fuzz »
I am using LAUNCH X431 Pros Elite V+ Pro3S+ Bidirectional Car Diagnostic Scanner Coding.
with can FD and doip
Disconnected the wiring harness at the left hand side door.
Now i heard that someone cut two wires in that car to test something. I have yet to find those cut wires.
Pelland
Post by Pelland »
what does the LAUNCH see when you have the wiring disconnected?
Any codes from anything?
What did it see when you had the pugs connected?
Fuzz
Post by Fuzz »
I will have to check that. It started to rain and the car is not at my place. So I could not carry out the investigation
Fuzz
Post by Fuzz »
Latest update found two wires that were cut close to the bonnet handle. Fixed them temperate back on the dashboard.
Still doesn't start but i have yet to scan the car again
Fuzz
Post by Fuzz »
Hi
Would be grateful if someone has any idea what could be causing the car not to start now.
I have scanned and cleared a few codes but these ones are active
C241713 Motor short or open-RH
C150113 Switch failure
C241613 Motor Short or open LH
AC Air conditioning”
B2447013 E-comp interlock fault
IBU-BCM
C160E00 P-CAN Bus off
Smart Key Unit
B16AD00 Passenger side door handle Antenna Failure
MDPS (Motor Driven Power steering)
C180287 CAN time out VCU
VCULDC
U0001 High speed CAN communication Bus
U0146 Lost Communication Gateway Á
EV Motor control system
U0001 High speed CAN communication Bus (P-CAN)
CCM (Charging control module)
C182C00 EVSE failure
C160E00-P-CAN bus off
IGPCM
C160E00 CAN bus off P-CAN
C182700 CAN Time -out iBAU
C165100 CAN time out EPB
E Shifter
C161688 C-Can bus off
Before repairing these two wires there was almost no communication with the modules
They stole the brake switch so one more issue solved
uhi22
Has thanked: 244 times
Been thanked: 684 times
Post by uhi22 »
* I would consider the "P-CAN Bus off" and related P-CAN errors still as critical error. A stable communication on the P-CAN is essential to drive. Maybe you find somebody with a CANoe/CANalyzer for detailled bus logging, or just SavvyCAN to get an impression what is going on.
* The "E-comp interlock fault" means that the HV connector on the compressor is not fitted (or broken wire or something), this sounds like drive-preventing.
* Also the C-Can bus off of the E-Shifter sounds critical. Also for this, an analysis of the CAN communication on this bus may help.
Fuzz
Post by Fuzz »
Thank you.
I think i have can modules i bought sometime ago. Need to look for them. I also installed can hacker.
Joining the wires to just replace the brake switch brought the shifter back to drive and neutral.
Will try and find a brake switch and move on.
Will also replace the 12 volt battery. Getting unstable battery voltage
Hopefully some more issues would be cleared
Here is the can module i have
Fuzz
Post by Fuzz »
Hi
Update
The car finally started and can be driven around. After replacing 12v battery and the stop switch.
Thank you all for your help.
If anyone wants help just let me know. I'm ready to help
Pelland
Post by Pelland »
Congratulations.
With all the error codes you still had I thought you'd still be some way off.
As a mater of interest what codes do you still have now that it's running?
Fuzz
Post by Fuzz »
Hi
Thanks.
I will check them out and post them.
My offer to help anyone who needs to read and write eeprom MCU still stands. I'm ready to share the little i know
Fuzz
Post by Fuzz »
Hi
I'm a bit puzzled now. There's only a fault in the passenger door sensor. Which is of course damaged.
The other faults cleared after replacing temperature sensor brake switch and 12v battery.
I don't know what's wrong with the igpcm. It was written faulty on it and it was changed. But there's no fault for now. Anyway the one i ordered is on its way.
So after restoring communication the battery and brake switch the car was up and running.
At the dealer they had replaced the battery the igpcm stole the brake switch temperature sensor and cut two communication wires.
Conclusion good 12v battery very important else you can have multiple communication faults
Fuzz
Post by Fuzz »
Hi
I need a favour can anyone tell me if doors from mk1 will fit Kona mk2?
Pelland
Post by Pelland »
I use this parts site to compare part numbers between models.
https://partsouq.com/en/catalog/genuine
Use the VIN on your car to get your P/N then the VIN on the donor to see if it's the same P/N. Different P/N usually means it won't fit.
Fuzz
Post by Fuzz »
Thank you very much very very helpful.
I need one more favour.
Can someone please send me the vin number of any Hyundai Kona MK1. I need it to check for the door if it will fit mine. I can't get doors for MK2
In my inbox. I know it's sensitive info and understand that it should not be shared on open forum
Thank you again
Fuzz
Post by Fuzz »
I have managed to get the car running. So anyone needing help let me know I will try my best to help
Pelland
Post by Pelland »
Congratulations on getting the car going.
Fuzz wrote: Sat Jun 21, 2025 2:48 am Conclusion good 12v battery very important else you can have multiple communication faults
I've noticed that if the battery isn't able to support the inrush current of the IEB (Brake booster) it will cause lots of resets and error codes.
