Kia Niro BMS
- bexander
- Has thanked: 78 times
- Been thanked: 102 times
Re: Kia Niro BMS
Yes, in your second case nothing is working as init fails as per " UARTSlaveDevicesWakeUp WD timeout".
In first case the slave com is up as there are no messages after "Daisy chain init", before "Set all slaves". You also get a response to a readAll command, 2 3 2 30 0 B0 A6 D3.
And later you get several reponds.
From the reponses it seem that you have poor communication integrety.
The last byte "D3" should be equal to the number of slaves you have connected, in your case "01".
And all of the alerts are regarding slave com.
This is a good start but I urge you to check slave com from the 17841 chip and onwards. Is all solder joints ok? Double check component values. Wiring? etc.
zuuus
- Has thanked: 4 times
- Been thanked: 3 times
Re: Kia Niro BMS
Thankyou, I think the isolator transformers im using are causing the problem. With everything wired up between the BMS and Module, I see that the signal before the transformers isn't the same after the transformers. So I will look at other ones that I can use. I will also check other components etc.
The iso transformers I have now are the SM91502ALE
EDIT: Looking at the datasheet of the SM91502ALE, it should work with my circuit
- bexander
Re: Kia Niro BMS
I use SM91501ALE which is basically two SM91502ALE in one package. So I don't think this is the problem.
zuuus
Re: Kia Niro BMS
Do these signals look right?
TXP before transformer TXP after transformer TXN before transformer TXN after transformer
- bexander
Re: Kia Niro BMS
They don't look bad to me.
How does the RX singals look before and after the transformer?
Re: Kia Niro BMS
Hi zuuus,
I assume you are running the above code and MAX17845 slaves. If you want to eliminate the possibility of hardware loopback problem use software loopback, this a bit hacky so some of the init needs to be bypassed. You should see 1 module active assuming you have the RX and TX pair wired up correctly to the slave.
- BMS_test_OI_modified2_max17845_lb.ino
- (46.86 KiB) Downloaded 26 times
zuuus
Re: Kia Niro BMS
RXP before transformer
RXP after transformer
RXN before transformer
RXN after transformer
With the BMS_test_OI_modified2.ino code from bexander
EDIT: Could someone scope their signals? Then I know what the signals have to look like. Did grab another module, but still no data coming out of them
zuuus
Re: Kia Niro BMS
Did test the BMS_test_OI_modified2_max17845_lb.ino but still no data and the same errorByte 4. So I think my signals are off or are not right.
- bexander
Re: Kia Niro BMS
The RX signals look very similar in amplitude to the TX signals, and that is a very good thing. Your signals seem ok at this stage.
In the last serial print out the last byte is 0xD3 which is very odd as it start at 0x00 and in incremented one step for each slave it passes on its way up the daisy-chain with no increments on its way down the chain. This should in your case end up with 0x01. 0xD3 equals 211 and that seem impossible to me? What happends if you connect all slave modules to thw wiring? If you can do this what is the serial output?
zuuus
Re: Kia Niro BMS
Yes 211 is indeed impossible. Don't know where this number comes from. Loose wires? I only have some cables for the loopback and all other connectors are not plugged in. So I think the 0xD3 is just a random number that the code sends? I will have a look at connecting all the slaves. Only got 2 modules missing. One module damaged and the other one lend it to a friend that also recently bought a E-208 pack. I will update my findings.
Also I get the same signal in the loopback that looks like image 1 en 3 from my post about the RX signal. Do these signal come from the MAX17854 chip on the slave PCB or from a circuit on the slave PCB. I don't think my MAX17854 is waking up? Or it doesn't recognize the signal i'm sending? This code was written for modules with a MAX17823 chip if i'm correct?
- bexander
Re: Kia Niro BMS
Well, the 0xD3 is on every message received so it is not random, which makes it very puzzling?
Oh, now I see the problem...
You have been writing MAX17854 all the time but I thought you ment MAX17845... The 845 works the same as the 823, which is the one the code is originally designed for. The 854 does up to 14 cells compared to the other that only do 12 cells. This explains alot!
- bexander
Re: Kia Niro BMS
After a quick look in the MAX17854 datasheet, it should be possible to port the code to work with this chip but it will take some work. Alot of the registers have different addresses, as @woleg says several times.
zuuus
Re: Kia Niro BMS
I thought I mention the chips I have on the board so there would be no confusion about what I have. It can happen to the best of us. I know it will take some work to rewrite the code. I am already thankful for you guys on the forum for helping me getting the module to work. I am happy to wait a few days for the new code. I'm guessing the newer packs use MAX17854 chips and the older packs MAX17845/23 chips? The latest date I could find in my pack was on the main BMS (that sadly is broken) 01/08/2022.
- bexander
Re: Kia Niro BMS
To be clear, I will not be doing this work as of now. I encourage you and others to have a look and give it a go.
Re: Kia Niro BMS
Your code should work fine up to the point of HELLOALL as addressing is common between MAX17823 and MAX1785x. To be clear, HELLOALL should return a valid number of slaves as is.
Whichever way you init the daisy chain, the processes is identical and you should also be fine with reading register 0 which returns the slave version for either variants. I have written a universal INO which covers both slave types, and the difference is mostly registers, setup, and balancing timers but the daisy chain init is identical.
Re: Kia Niro BMS
0xD3 is a fill byte as described in the following data sheets - so there may be an off by one issue here.
https://www.analog.com/media/en/technic ... X17843.pdf
https://www.analog.com/media/en/technic ... X17854.pdf
https://www.analog.com/media/en/technic ... 17823B.pdf
https://www.analog.com/media/en/technic ... 17841B.pdf
I did not know you have damaged packs. You need to start with a known good controller to isolate the problem.Fill Bytes
In the READALL command, the host sends two fill bytes
for each device in the daisy-chain. The fill bytes are the
locations within the packet and are used by the device to
place the read data. The fill-byte values transmitted by the
MAX17841B interface alternate between C2h and D3h.
As the command packet propagates through the device,
the device overwrites the appropriate fill bytes with the
register data. The device uses the ADDRESS register to
determine which specific fill bytes in the packet are to be
overwritten.
zuuus
Re: Kia Niro BMS
Is this code from your GitHub? https://github.com/analogdevicesinc/MAXREFDES1277
Im guessing if I use this it will not work because it uses the EVKIT board
Do I use BMS2_7_3 or BMS2_7_4 as a start?
I have done some c coding so I will give it a try to edit/add the registers for the MAX17854
zuuus
Re: Kia Niro BMS
So I tried modifying the code to the MAX17854 chip. But I realized that this requires more experience than I have. Also understanding the datasheet and converting this to code is also challenging for me. Could someone help me figure it out? This is what I have as of now.
- BMS_test_MAX17854_v01.ino
- (37.57 KiB) Downloaded 22 times
Re: Kia Niro BMS
You should not need to modify anything to get this working which leads me to believe you have faulty hardware.zuuus wrote: ↑Wed Dec 03, 2025 10:16 am So I tried modifying the code to the MAX17854 chip. But I realized that this requires more experience than I have. Also understanding the datasheet and converting this to code is also challenging for me. Could someone help me figure it out? This is what I have as of now.
The module addressing routine for both MAX17823 and MAX17845 is identical. If you are not getting a sane response to HELLOALL then it is not Bexander's code at fault. Everything after HELLOALL is model specific.
zuuus
Re: Kia Niro BMS
After a long break due to having to do other stuff I started working again on my project. A friend of mine bought also Peugeot E-208 packs. He got the pack with the modules having MAX17823 chips. The BMS2_7_4 code from Manny works with the MAX17841B and MAX17823. So my BMS board that I made from Manny works.
I haven't worked on the code for communication between the MAX17841B and MAX17854 pack since my last post. The other pack has MAX17854 chips and NOT MAX17845 chip. I have confirmed the slaves with the MAX17854 chips are working with a BMS from another MAX17854 pack.
I'm going to start again on trying to communicate with the MAX17854 chip. Any help is appreciated since i'm not really good at transforming datasheet language to code.
zuuus
Re: Kia Niro BMS
It has been a while since I posted here. Had to pause my project a bit due to school. I'm slowly getting back on my project. Wanted to give a update. I got the communication working with the MAX17854 chip. I can read cell voltages. Now working on getting temperature measurements working. I'm not really that good at coding so there is some AI code. This is what I have so far. Feedback is always welcome!
- BMS2_7_4_MAX17854_CELLOK.ino
- (50.82 KiB) Downloaded 11 times
zuuus
Re: Kia Niro BMS
I have now also temperature working on the MAX17854 modules. Also made the serial output more clearer to read and made some small improvements so it uses less dynamic memory. The code is still in testing phase as i'm testing cell balancing on the modules.
- BMS2_7_4_MAX17854_CELLOK_TEMPOK_v2.ino
- (52.36 KiB) Downloaded 10 times
