48 volt options for HSG / citroen ami CAN
stanislavz
Has thanked: 5 times
Post by stanislavz »
Hello. First post here.
Google internet for few wees by now. I was not able to find any way of reusing current hsg motors (valeo) as is, with inbuild controllers. They are very nice and neat packages, for lower power applications. However - same motor is used as drive in citroen ami and its clones. And then its beeing "chipped" - only body ecu is sent for re-flashing. For both power and removing of speed limit.
Any deeper info on it using can spoofing ?
Thank you !
Has thanked: 330 times
Been thanked: 848 times
Re: 48 volt options for HSG / citroen ami CAN
Grab CAN logs of the AMI driving.
stanislavz
tom91 wrote: Wed Nov 19, 2025 5:57 pm Grab CAN logs of the AMI driving.
Will need to find one first. And firmware inside dedicated hsg may be different from ami.
Then find the car you got the HSG from and log that...
stanislavz
tom91 wrote: Fri Nov 21, 2025 9:35 am Then find the car you got the HSG from and log that...
And have big black box of unknowns.
? What are you on about. You need to get CAN logs play them back to spin the motor then reverse engineer it.
This is just the process of how to do this if you do not have the OEM info. This process has been done by myself and others on this forum many times to great success.
bigmotherwhale
Has thanked: 17 times
Been thanked: 25 times
Post by bigmotherwhale »
Check the last couple of posts on this thread: https://openinverter.org/forum/viewtopi ... 704#p81704
There is some can logs of a running AMI, let me know it fit works.
