Most of the interest so far seems to be from new usernames looking to control this transmission in ice powered vehicles.
For people interested in the electric side of this but silent and or confused, here's some info to help understand the significance of this transmission / hybrid transmission.
200kw (250hp) is what some of the hybrid variant electric motors are rated to but couple that with 8 speeds. For reference, the gs450h is rated to 147kw and has 2 speeds.
The 8hp was designed with fuel economy in mind, lots about down speeding the ice but likely also means they looked at lower drag components / design too (read as efficiency for us). It was also designed to target dual clutch transmission shift speed of .2 seconds, it's not a slushbox.
There's a very large list of vehicles which use this transmission, a ton of availability in RWD and AWD variants across lots of power ranges.
https://en.wikipedia.org/wiki/ZF_8HP_transmission
This specific reverse engineering is targeting the bmw hybrid transmission but the controls will likely cross over to other variants as well. No promises but likely in zf packaging this for so many different vehicles.
Taking on projects like this is a ton of effort. If you're interested in this transmission / hybrid transmission run in electric mode, please throw a like (
) to Damien's original post to show interest if you haven't.
While likes help understand interest level, contributions help immensely to make these projects actually happen. Please consider supporting Damien on Patreon if you can.
https://www.patreon.com/evbmw
If everyone interested contributed even a small amount it would go a long way towards helping make this happen.
I and others will help how we can to make this happen as well.
Please show your support how you can.
