I'm wondering how your German road legal papers look like. We have a self configured battery. For that reason we have maybe more entries in the papers than you guys. You will see that some things are not right, if you try to control with the calculator. I don't want to blame anyone here, just want to know how it's documented in your papers. (Try to translate that to English)
- Motor is From Tesla S
- Motormount ist self created
- System has 157,5 Volts
- 180 battery cells a 3.2V EVE .....
- Capacity 60,48 kWh
- Interconnection 2P90S
- Battery box is made of Aluminium
- Charger are mounted on an Aluminium plate behind the radiator grille. Manufacturer .... 230V/16A.....
- Heater PTC element manufactor..... 2x 2.235 kWh
- Brakes with vacuum pump manufacturer...... connected with Klemme 15
- Inverter Curtis 1239e.......
- DC/DC converter Meanwell RSP-1500
- Chargeport Type 2
- Range about 250 km
