AWD hybrid project
Yuyu29
AWD hybrid project
Post by Yuyu29 »
I'm working on a project to convert my Pontiac Fiero into a AWD hybrid, using a Mitsubishi Outlander rear drive in front-wheel drive and my 13b combustion engine in the rear, using an HSG to start and charge the battery.
Can an HSG like the ones used in a BMW I8 or Hyundai be controlled with a Volt inverter, and have that inverter also be the Outlander rear drive? The other option I had in mind is the Prius Gen3 inverter.
Joowerss
Re: AWD hybrid project
Post by Joowerss »
One inverter can’t reliably run both. Best to keep the Outlander rear drive on its OEM inverter with a CAN VCU, and use a Prius Gen3 inverter for the HSG—simpler and proven. What pack voltage are you targeting?
Has thanked: 480 times
Been thanked: 137 times
Post by Jacobsmess »
A prius inverter would be able to control both but performance may be lacking.
Scrappyjoe
Has thanked: 42 times
Been thanked: 26 times
Post by Scrappyjoe »
@Joowerss do you have any links to demonstrations of the Prius Gen3 inverter controlling the HSG? That sounds quite interesting and I'd like to try it out.
I think they meant the inverter itself is proven. I've not seen any combinations of the HSG and prius inverter myself.
