Can't log in to the forum
CrAzYDrIveR2
Post by CrAzYDrIveR2 »
Is it because my user name has a "_" and it is not allowed on new users?
My posts are up.
Deleting cookies do not work.
Tested on chrome edge brave.
get url for photo
Mhs
Has thanked: 311 times
Been thanked: 13 times
Re: Can't log in to the forum
Post by Mhs »
Read this, could be related
viewtopic.php?p=85304#p85304
Zombieverter
CrAzY_DrIveR
Has thanked: 13 times
Been thanked: 8 times
Post by CrAzY_DrIveR »
Worked, had to login to https://openinverter.org:8443/forum/ accept terms prompt and log back to this one.
Before deleting cookies i thought the forum was dead.
Users need to be logged out to see the forum.
Been thanked: 1914 times
If only someone with the problem could pull a traffic log from their browser
eee291
Post by eee291 »
Finally i can log in. I almost gave up.
Pelland
Has thanked: 11 times
Been thanked: 20 times
Post by Pelland »
HI, I had the same problem. Luckly when I cleared all site data I could see the forums and found this thread. the :8443 port worked and I can log in OK.
johu wrote: Fri Aug 22, 2025 8:05 pm If only someone with the problem could pull a traffic log from their browser
I have captured firefox network and console messages. I have a HAR and a LOG file if they are of any use.
Please let me know where to send them if they are useful.
Very good, just zip them and send via PM
Make sure the naming reflects the good and the bad case
So, looking at the log file I found
Loading failed for the <script> with source “https://openinverter.org/javascript/core.js?assets_version=”. index.php:218:51
The stylesheet https://openinverter.org/forum/index.php?assets_version=100 was not loaded because its MIME type, "text/html", is not "text/css". index.php
Uncaught ReferenceError: jQuery is not defined
So instead of looking for core.js in /forum/assets/javascript it links to /javascript
Now instead of actually getting to the bottom of this I simply created /javascript and soft-linked the file there. Lets see what happens
dukbilt
Has thanked: 7 times
Post by dukbilt »
CrAzYDrIveR2 wrote: Fri Aug 22, 2025 8:27 am Is it because my user name has a "_" and it is not allowed on new users?
My posts are up.
get url for photo
"Worked, had to login to https://openinverter.org:8443/forum/ accept terms prompt and log back to this one.
Users need to be logged out to see the forum."
Thank you Crazydriver and Pelland!
I had this exact issue for months - thank you for being able to raise this post, as I thought I had been blocked.
I finally decided to sit down and work my way through, but I thought I was never going to get back on!
JeremyMakesThings
Been thanked: 22 times
Post by JeremyMakesThings »
johu wrote: Wed Sep 10, 2025 8:19 am Lets see what happens
I was still having trouble logging in, then I found this thread. I'll send you my log and har via PM in the hopes you can find something
Through some more research I've now found this: https://www.phpbb.com/community/viewtopic.php?t=2336856
Patched it in, lets see if it helps.
I've played with the firewall again, it now runs within Docker. Has anyone had trouble logging in lately or is it all well?
It's probably pointless to write it here but you need to delete cookies if you end up in and endless loop
