Hope I can list this here. It is not directly intended to go into an EV but closely related.
I'm selling my new in opened box HYD 20KTL-3PH hybrid solar inverter.
I bought it since it has two DC input busses and 20 kW AC 3-phase output.
My plan was to use one DC input for a fixed battery and connect and EV conversion via CCS to the other one.
That would result in a CCS fast charger as well as V2H solutions.
However I found out I have too many ideas and not enough time.
I paid 2500 euro ex VAT.
Asking 1750 ex VAT
It will come with a .dbc that allows you to communicate via CAN with it and act as a BYD HV battery.
I have not tested it on this unit (as it is new in box) but my .dbc has been validated on a setup with a HYD 20KTL-3PH and an official BYD battery.
Shipping from The Netherlands is possible, but it is heavy (37 kg) so will need to be on a pallet and therefore will not be cheap.
Sofar HYD 20KTL-3PH hybrid inverter
- larsrengersen
- Has thanked: 16 times
- Been thanked: 36 times
creeperstroke
- larsrengersen
- larsrengersen
