2017 30kWh main harness connector pin diagram
GregFordyce
Has thanked: 43 times
Been thanked: 29 times
Post by GregFordyce »
Pinout diagram for the motor main harness connector on a 2017 30kWh Leaf. It's a differnet connector than my 2015 Leaf and also appears to be the same as a ZE1 Leaf as per this post. I have used the same numbering system from that post because I couldn't find a Nissan diagram of the connector. All other pin numbers are as per Nissan.
Corrected CAN bus pins 2025-07-10
AZEO motor harness connector (2).ods
(290.87 KiB) Downloaded 73 times
Peugeot Expert LWB 2009
Zombieverter - Full Gen2 Leaf stack
24kWh & 30kWh Leaf batteries in custom battery box under van
GregFordyce
Re: 2017 30kWh main harness connector pin diagram
I found some errors in the CAN bus pins and have re-uploaded the corrected files above.
cnstrct
Has thanked: 11 times
Post by cnstrct »
Thanks for mapping the pins for the main harness GregFordyce! I have a 2017 so I have updated my diagram, would be great if you could give it a look over.
I now have the ZombieVerter and have wired up my harness, so it's bench setup time soon :)
Questions:
- Given 36 & 37 and 45 & 46 go to the same pins, I'm thinking i don't need to run the canbus to both?
- Both stock Leaf charger sockets are still connected to the main stack, I'm unsure about where pins 35 &44 go? I watched Damian's video, and he talks to the wires going to the charging socket but I can't seem to find the documentation about precisely where those wires attach?
J0hannes
Has thanked: 21 times
Been thanked: 182 times
Post by J0hannes »
The CAN for Inverter and PDM are joined in the engine bay side harness, so you need to connect CAN H and CAN L for both on either side of the connector. Up to your preference, whichever way you want to do it :)
The 35 and 44 go to the AC charge port
cnstrct wrote: Tue Jul 22, 2025 8:38 am - Given 36 & 37 and 45 & 46 go to the same pins, I'm thinking i don't need to run the canbus to both?
GregFordyce
I connected to both sets of canbus wires but either set should be fine.
