Leaf Current Sensor instead of IVT-S
I was wondering whether we could use the current sensor of a leaf contactor box that is connected to the Leaf BMS?
The leaf inverter can measure the voltage for precharge so an IVT is not strictly necessary anymore.
Current measurement is needed for CCS and general limits but needs to be implemented via external current sensor, why not use the internal one (connected to Leaf BMS or directly to a VCU) or did I miss something?
- Has thanked: 209 times
- Been thanked: 577 times
Re: Leaf Current Sensor instead of IVT-S
Not possible with the Zombie as it is not coded in.
Do you have specs on what the leaf current sensor is?
If you are talking about CCS I would expect you to have a BMS and the BMS should be measuring the current and reporting it.
Ok thank you for the quick clarification.
The leaf current sensor is a normal hall sensor but with a small offset (0A => 3.25V, instead of expected 0A => 2.5V with normal 5V logic hall sensors).
So basically an ADC reading would suffice but the value needs to be mapped to CAN. This is option 1: connecting sensor directly to VCU and getting current values for things like CCS, monitoring, etc. from there.
But does the leaf BMS not output the current value via can? Then one could connect the current sensor to BMS as intended and rad the current from the
CAN bus which would lead to option 2: leaf BMS + current sensor replaces shunt.
Just a thought of mine, which came up when I connected a leaf conntactor box and saw the unused current sensor. If one of the options works, then Leaf Stack users could who also use BMS and leaf cells can omit the expensive IVT-S shunt completely.
... just like Damien done on his truck with the latest firmware release.
Right, but as far as I know the last release made use of the voltage value provided by leaf interver.
Is the current value of the junction box also used? I don't think so as it is connected to the BMS and is never mentioned anywhere, so I thought it might be worth talking about it
Really?
You watch any of the Damien youtube videos? The Leaf BMS is implemented in the Zombie release 2.20A.
also on the wiki https://openinverter.org/wiki/ZombieVerter_VCU
The BMS is i know.
But does it use the current sensor in the junction box? It may or may not I don't know that's why I asked. Sorry maybe I did't find the right words to express what I was trying to say...
The Leaf BMS is included but where is the information about the current sensor?
When reading the code I found that:
What made me think was the ShuntType 0 and isa sensor part. As the sensor originally used with the leaf battery is a hall sensor not a shunt ?
From the code I can't see where this hall sensor should be used?
To put it in other words: When using Leaf BMS with Zombieverter do I need to have the leaf junction box and current sensor connected to the BMS?
As I can't find an equivalent part in the source code and you mentioned Zombieverter doesn't use the current hall sensor.
-> wouldn't that be something good to add as it would make other current measurements obsolete just like the last FW made voltage sensing obsolete?
if (Param::GetInt(Param::ShuntType) == 0)//Only populate if no shunt is used
float BattCur = cur / 2;
float BattVoltage = udc / 2;
Param::SetFloat(Param::idc, BattCur);
if(BattVoltage < 450)Param::SetFloat(Param::udc2, BattVoltage);
if(BattVoltage > 200)Param::SetFloat(Param::udcsw, BattVoltage - 20); //Set for precharging based on actual voltage
float kw = (BattVoltage*BattCur)/1000;//get power from isa sensor and post to parameter database
Param::SetFloat(Param::power, kw);
- Has thanked: 382 times
- Been thanked: 1575 times
The LeafBMS has a current sensor connected to it. There is no separate junction box logic.
Great. And does the BMS report the current values to the CAN Bus? If so I would like to add this information to Nissan Leaf Wiki pages, as I think that's something to consider.
Yes
The wiki links the info https://github.com/dalathegreat/leaf_can_bus_messages
