J0hannes wrote: ↑Mon Jun 30, 2025 8:31 am
It is so cool, that you actually have
portal axle gearing on that!
I suppose the gear reduction axle transmission you refer to is the gearbox on the wheel hub?
A benefit is increase in ground clearance under the axle, but downside additional possible failure point and transmission losses.
You may want to open those boxes and see how beefy gears they have in before giving full chooch of the Leaf motor
Thanks for the link, JOhannes. Very Interesting read. I was told that it was a 1T transporter and the Wiki Confirms that!
"In 1962, a heavy-duty Transporter was introduced as a factory option. It featured a cargo capacity of 1,000 kg (2,205 lb) instead of the previous 750 kg (1,653 lb), smaller but wider 14" roadwheels, and a 1.5 L, 31 kW (42 PS; 42 bhp) DIN engine. This was so successful that only a year later, the 750 kg, 1.2 L Transporter was discontinued. The 1963 model year introduced the 1500 engine – 1,493 cc (91.1 cu in) as standard equipment to the US market at 38 kW (52 PS; 51 bhp) DIN with an 83 mm (3.27 in) bore, 69 mm (2.72 in) stroke, and 7.8:1 compression ratio.
I'll check the gears in the portal axles soon and post pics,
