[WIP] Upgrade a converted Citroën DS Electric
duivekeet
Been thanked: 9 times
Post by duivekeet »
Hi all,
I am Henk and I have converted a Citroën DS in 2013 and a Renault Estafette(Estaleaf) in 2022.
After my experience with the Estaleaf, I decided to upgrade next year my Citroën DS.
The DS has a 30kW(nom) Fimea motor with a Curtis controller, a 36kWh LiFePo4 batterypack (degraded to 30 kW) with a range of 150 km.
Charging with 11 kW type 2 connector. 3 phase.
The Estaleaf has a 80 kW Nissan leaf motor controlled by a Resolve-ev controller and a 62 kWh batterypack range 250-300 km.
Charging, Chademo an 1 phase 6.6kW type 1 connector. (original Nissan leaf)
By the DS I am missing fastcharging and by the Estaleaf I am missing 3 phase charging.
The DS is my daily car.
What I want to have in the upgrade for the DS is: CCS charging, 3phase charging,more power and a MEB 55kWh batterypack.
I want to do everything step by step.
So I purchased at this moment a 110kW Nissan leaf motor, a zombiecontroller and a Issabelle shunt.
For testing I have a old Nissan leaf batterypack.
For now, everything is on the testbench and the motor turns.
Only I have some problems.
When I set the REVLIM at 1000 RPM, I push the throttle and the motor turns about 3000 RPM.
Then I have to slow down the motor below he 1000 RPM before the motor reacts again on the throttle.
If I set the REVLIM at 6000 the motor works normal.
The next problem is that, when I set the THRORAMPRPM at 5000 RPM and the motor goes above that, and the
throttle is going back to 0%, the motor still increases. To stop the motor I must turn the driveswitch to OFF.
thanks in advance
duivekeet
Re: [WIP] Upgrade a converted Citroën DS Electric
Post by duivekeet »
Last weekend I finised connecting the gearbox to the Leafmotor.
I rebuild the gearbox with only the second gear working. The ratio from the second gear is about 1:8.5.
marcexec
Has thanked: 1044 times
Been thanked: 111 times
Post by marcexec »
duivekeet wrote: Mon Apr 29, 2024 7:53 pm When I set the REVLIM at 1000 RPM, I push the throttle and the motor turns about 3000 RPM.
I think that is common with unloaded motors, have you connected it to the gearbox at least?
If not resolved, you might want to put these questions in the ECU forum: viewforum.php?f=39
Also, lovely condition on both cars!
My Suzuki RF400 build @ES
Honda IMA & Lebowski howto
duivekeet
Post by duivekeet »
Last year I started preparing to upgrade my DS. Since we bought a house in Roosendaal this project was on hold for a while. But I am working on it again. At the moment I have the testset running with 8 MEB batteries equipped with a SimpBMS with display, tesla DC/DC charger, Tesla Charger Gen2,
Isa-shunt, Zombieverter and a Leaf 110 kW motor.
I have also made preparations to be able to charge CCS in the future.
Everything seems to work.
Has thanked: 330 times
Been thanked: 848 times
Where did you obtain the SimpBMS from? I recently got notified EV-Shop has ripped off my board design and are selling them on without my consent.
duivekeet
Post by duivekeet »
It's been a while since I posted anything. In the meantime, I've restored the chassis and installed the test setup in the car.
Here are some pictures of the conversion
It looks like everything is working including the hydraulics.
marcexec
Post by marcexec »
Wow, looks amazing, especially the battery placement!
