This will be a dumping spot for some of the fine details for the integration.
Also to document some of the Fails of the journey.
Cluster:
I was hopeful that the engineering option of turning on the Hybrid menus in the Gateway/Cluster/Radio modules would allow me to hijack the existing hybrid integration. Unfortunately after many trials I'm pretty confident that the 991 and 981 cluster firmware lacks any deep hybrid integration.
For those wondering, you can flash a Cayman cluster with 991 firmware and gain the few perks of the 991 (better selection of the lcd panel)
But even with the latest version, the cluster fails to read the ECU Hybrid canbus signals and thus cannot forward the signals onto the PCM/Radio.
I have a feeling the Panamera/Cayenne clusters would work, but unfortunately these were made by VDO (vs Contentinal for the 991/981/macan versions) so the code is most definitely incompatible given the blocksize for the bootloaders are different.
I may try to pickup a cheap cluster to map the signals sent to the PCM to display the battery and charge status there.
Also fighting being unable to find any documentation of the BAP protocol to the PCM.
I've managed to identify 0x10E (I believe, need to check my notes) if you spoof this on the MMI bus it'll toggle the E-Range value.
Eventually I hope to just have a small CAN-in-the-middle to adjust these values to the PCM if I can't sort out the actual cluster forward
With PIWIS you can also toggle the AWD screens and mimic the Allrad block to show the torque distribution.
Some AWD cluster warnings can be triggered by 0x105, though I haven't seen any DBC showing the full breakdown, I can post the info that I've found from spoofing.
There is an AWD screen that should be easily enabled much like the hybrid screen, but on the 981/991 images this screen option does not appear. I doubt there is any selective logic on Canbus signalling (and no errors from the cluster complaining about a missing canbus message)
I was going to try the Macan cluster firmware to confirm the hybrid and AWD screens are missing from that one as well, but that may be too risky.
Finally, you can adjust the cluster bar graph scaling for most of the values, so it's easier to better represent the cooler coolant temps and such related to the electrification, as well as adjust the oil pressure and other items to better represent whatever you need them to.
Gateway:
Looking into if there's an updated firmware for my existing CAN gateway.
Like most VAG cars, there are only a few different modules, and most are used elsewhere in the model lineup.
Unfortunately the module I have is the 7PP.907.530
There is a 95B module, this is the macan module, but also used in the 918 and most of the later model lineup. This module seems to have many more configuration options.
Unfortunately due to the component protection, I can't just swap out the modules without dealer reprogramming.
My Gateway is ver A4.2
The 95B module is A7
