Bench test hardware
r1ckyb0nd
Bench test hardware
Post by r1ckyb0nd »
As I am getting started on my projects, what are some.of the good equipment, other then multimeter, someone needs. I would like to be able to power both the LV and HV side of an inverter to test.
Has thanked: 264 times
Been thanked: 717 times
Re: Bench test hardware
What inverter, what motor, what board/vcu?
A decent power supply that can do 12V at like 5A is a good thing to have.
HV power supply, no point really for spinning a motor.
Scrappyjoe
Has thanked: 42 times
Been thanked: 26 times
Post by Scrappyjoe »
I’ve got a multimeter and a variable voltage power supply that can go up to 60v. With those two tools you can get a very long way.
Zieg
Has thanked: 165 times
Been thanked: 159 times
Post by Zieg »
Contactors and a precharge resistor, and depending on the wiring situation you might want a bunch of extra pins to populate your connectors for bench testing before doing the final wiring in the car.
Incandescent bulbs or stove heating element for verifying polarity?
