Writing application for Stm32F105 @ 25 MHz
Mitchy
Has thanked: 7 times
Been thanked: 91 times
Re: Writing application for Stm32F105 @ 25 MHz
Post by Mitchy »
Just a heads up and also inquiring if anyone else has seen this.
Ordered 5 more Can Bridges with the blue PCB, all with F105s, They look legit, at least the dies are marked from either China or Philippines,
Cube programmer can write to them, clear, etc. and show up as 0x418 device code.
My working codebase doesn’t show any life on these other units.
Took a firmware dump of my working unit, confirmed the new units have identical code via firmware comparison.
Both have the 25 mhz crystal.
Haven’t dug too deep into it yet, most likely a counterfeit chip, but just need to figure out what’s required to get it running effectively.
Mitchy
Post by Mitchy »
Just to report back,
Seems the last batch I received have a weak pulldown on the BOOT0 circuit, or else there's some leakage somewhere.
1 out of 5 of the units worked out of the box... That's to say, one worked maybe with some added resistance with a finger or such.
I figured I'd try to ground the BOOT0 pin, and sure enough, all of them fired to life.
Copied over the picture from the reverse engineering site: https://dangerouspayload.com/2020/03/10 ... er-device/
WillK
Has thanked: 65 times
Been thanked: 8 times
Post by WillK »
One query I have is after programming/flashing, I need to fully power cycle things before SDO/CAN come back.
Likely some Init is missing, but if anyone noticed a similar issue and has a fix, would save me some time in trial and error.
I have the same, haven't found a way around needing to power cycle other than a push-to-break switch on powerline for testing.
I've found that can2 doesn't work very well for sending multiple messages. I was planning on filtering messages from can1 & propagating modified messages to can2, but can2 doesn't seem to be able to keep up with the rate of messages and drops, so I've reverted to just using can1.
WillK
Post by WillK »
Just documenting the procedure for unlocking the flash memory on a new board
In stm32programmer
- select "option bytes" OB side tab
- uncheck RDP (read protection option byte)
You can then upload firmware via the Erase & programming tab. Hex files are the most straighforward as these will set the base address automatically.
