450H inverter polarity
CapriV
Has thanked: 39 times
Been thanked: 27 times
Post by CapriV »
Hi. Quick question on the inverter.
Is the HV polarity the same orientation between RHD and LHD inverters, ie, positive always on the left, negative on the right?
This pic from the wiki looks like the RHD unit
Mines from a LHD, has the HV connectors on the opposite side of the inverter. Are the + / - the same?
MANY THANKS
robertwa
Has thanked: 129 times
Been thanked: 157 times
Re: 450H inverter polarity
Post by robertwa »
Polarity is the same as above on LHD models. You can also test this using a multimeter in diode mode between the HV bus and one of the motor phase output terminals
