Thank you for quick response, I'll do that
Simp BMS
Re: Simp BMS
Please see the current settings on the dashboard. Let me know if you see anything I'm missing.
- Has thanked: 207 times
- Been thanked: 563 times
Re: Simp BMS
When I plug In the EVSE it indicates ready on the EVSE. Nothing happens, no fan, no charge. I have 12volts at the simp charge, good ground. All connections are secure. I have the proper resister in place as well. I was wondering if any of my parameters need to be adjusted in the photos above
Re: Simp BMS
This is not the SimpBMS but Vero-BMS I believe reach out directly to them. https://veroelectric.com/product/vero-bms-v2
Re: Simp BMS
Hello
Has anyone run simp bms on lilygo T-CAN485 ESP32 segregator RS-485 ?
https://pl.aliexpress.com/item/10050036 ... pt=glo2pol
