1. Wire Connections
Yellow = Ignition (12V)
Yellow/Black = CAN High
Yellow/Brown = CAN Low
CAN bus speed = 500 kbps
2. Send Required CAN Messages
Mandatory messages:
0x130 (Terminal status) every 100ms
Example: 0x45 0x41 0x21 0x8F 0x24
0x1A0 (Vehicle speed — affects assist level) every 50ms
Example: 0x00 0x80 0x00 0x00 0x80 0x00 0x78 0x1B
0x1D0 (Engine run) every 50ms
Example: 0x61 0xFF 0x6E 0xD2 0x24 0x78 0xCC 0xA4
3. Vehicle Speed Message 0x1A0
The first byte (data[0]) seems to influence assist (e.g., 0x00 = light steering, 0xFF = heavy).
Second byte (0x80 at rest, 0xB0 when moving) to signal movement state.
electric power steering mini cooper (R56) [SOLVED]
Re: electric power steering mini cooper (R56)
i will try and reply thanksmane2 wrote: ↑Mon May 19, 2025 1:07 pm 1. Wire Connections
Mandatory messages:
- Has thanked: 328 times
- Been thanked: 847 times
Check @mane2post and the other information in this thread
Hi Mengu
Did you manage to get the EPS working on your Mini. I also run my Mini on Maxx ecu and have everything working except the EPS
