- Gregski
- Has thanked: 633 times
- Been thanked: 1610 times
Re: 1971 GMCe Lexus GS450H BMW 530e Tesla Model S Electruck
watch this Certified Zip Tie Technician attempt to explain how a pre charge circus works
- Gregski
bigger 24 kWh BMW battery pack going in tonight, this should give me a range of just over 80 miles
modules arranged in installation formation
the patented porcupine design
- Gregski
well then I saw this mess and I just couldn't let it go...
- Gregski
So now lemme tell you what I'm not supposed to tell you, the extra curriculars
so it all started with me wanting to relocate the water pump which then led me to this, replacing the radiator, and I did this for a couple reasons, first I got tired or using many reducer hoses to step down from like 1 1/2 inches down to 3/4 for the Tesla water pump and even further down to 5/8ths for the inverter, and transmission
and the second reason was cause the darn bottom outlet port on my stock Chevy radiator headed straight for the passenger side frame rail, so I needed a narrower radiator, complements of this sexy 2014 Nissan Versa
Mandatory Stare 'n' Compare
the new Versa rad has only 1 1/8th inch inlet and outlet
all moched up
notice how the bottom outlet clears the frame rail now - Winning !
all moched up
- Has thanked: 363 times
- Been thanked: 249 times
Consider blocking some of the grill off if you haven't. You likely don't need that much of an opening with your reduced cooling needs. Should help you get some more mileage.
- Gregski
you all ever werk on your car and say ahhh I'll do that later, well looks like now it's later for the Greg and he is going around and a fixn' everything he should have done did right the first time
here I am finishing loomin' the OEM headlight wire harness, I swear once I run out of this corrugated split wire loom (pronounced: cheap crap) I am graduating to that sexy braided expendable wrap like all the cool kids be runnin'
- Gregski
I swear there's a wire mess every where I look, that green and yellow wire bundle is the stock rear lights harness, and all I really have going to the OEM bulkhead (everything else was engine related and has been deleted) is the red wire which supplies main 12v power to the OEM fuse box in the cockpit, the tiny black wire is the signal for the Prius EPAS Electronic Power Ass. Steering, this should get cleaned up tonight, so that my brain can function and not be distracted
that's a little gooder
Alibro
- Has thanked: 506 times
- Been thanked: 325 times
Re: 1971 GMCe Lexus GS450H BMW 530e Tesla Model S Electruck [Upgrade]
Just follow my mantra and all will be well.
"If you can't be bothered to make it tidy, cover it up"
You're bound to have a suitable 'something' that will hide all sins.
- Gregski
ha ha, you mean like I've been hiding this fugly Prius power steering mess for over a year, note the unclipped zip ties, how recluse it that?
I can live with this
- Gregski
Progress Not Perfection
I live my life one module at a time!
- Gregski
- Gregski
GMCe DIY EV 24 kWh BMW Battery Pack Upgrade
- Gregski
how it started...
- Has thanked: 545 times
- Been thanked: 153 times
Wow, that's a real nice paint job on that piece of card.
- Gregski
how it's goink...
[ just a trial fit, so please put away your EyeCrometers ]
meanwhile at the lesser known, Send, Notch, Send Facility
Alibro
Nice box!
Not even slightly jealous!
- Gregski
- Gregski
rethinking the component placement, not in love where the black box has taken residence
good ol' air cooled first gen Chevy Volt DC-DC alternator
and above it in the middle(ish) is it's older sibling first gen Chevy Volt battery charger
- Has thanked: 330 times
- Been thanked: 848 times
I see a lid for the top, is there a Bottom to the Battery box?
Also the SBox outside the battery box, thats a NO-NO in my opinion as its the thing that shut off HV from leaving the box. It is also clearly not waterproof in any way.
- Gregski
so my Alibaba 400x300x200mm Electrical Outdoor Metal Waterproof Vented Junction Box With Fan finally arrived
$112 bones
BMW 530e sBox inside for sizematology reference
BMW i3 Safety Box inside for a size reference
$112 bones
- Gregski
a little sneak peak ahead to Phase III, we will be upgrading to a 6 Killer Whaler battery charger/dc-dc combo unit, and rolling our own contactor/junction box
no Phase II is not completed, you did not miss anything
that gray box looks ridiculous
Alibro
Nice looking box.
Too rich for my tastes tho.
- Gregski
I hear you, well it all started with $52 bucks, then the fees, charges and taxes added up
Alibro
Is that your 'Trump Tax' that was meant to be absorbed by the importer costing $36.75?
Oh!, I guess you're the importer.
