what charger do you recommend?
r4rabbitx
Post by r4rabbitx »
I purchased a chevy volt pack for use in a 450h conversion. I realize the pack has a small capacity, but I plan on getting a second pack to help with range.
My question is, what charger do you recommend? It's possible that I can get a hold of the charger from the Volt, but I wanted to get your recommendations. A friend who has converted a vehicle has recommended a Tesla gen 2 charger, but, again, I wanted your thoughts. There are a lot of chargers out there, so what could give me the best bang for buck
Thanks!
Has thanked: 168 times
Been thanked: 351 times
Re: what charger do you recommend?
Well that depends on a few things…
Desired level 2 charging speed for one…
The Tesla gen2 charger is a 10kW charger
Model 3 pcs is a 7kW charger +dcdc
Volt is a 6.6kWh (?) or 3.3kW
Outlander is 3.3kW charger + dcdc
Some of the MG units has v2g, which Damien is working on.
also cost, size and availability
Not to mention the control methods
Has thanked: 403 times
Been thanked: 260 times
Post by MattsAwesomeStuff »
Bratitude wrote: Thu May 01, 2025 1:35 am The Tesla gen2 charger is a 10kWh charger
Model 3 pcs is a 7kWh charger +dcdc
Volt is a 6.6kWh (?) or 3.3kWh
Outlander is 3.3kWh charger + dcdc
kW. Not kWh.
Zieg
Has thanked: 152 times
Been thanked: 146 times
Post by Zieg »
Depends on the BMS you're using too, what kind of charger can it communicate with?
P.S.Mangelsdorf
Has thanked: 234 times
Been thanked: 271 times
Post by P.S.Mangelsdorf »
Bratitude wrote: Thu May 01, 2025 1:35 am Volt is a 6.6kWh (?) or 3.3kWh
Gen 1 Volt had only 3.3kW, Gen 2 had 3.3kW and then a later 7kW, related to the Bolt.
Gen1 Volt is CAN controlled and built by Lear. Gen 2 is PWM controlled.
I personally like the Bolt charger. Fairly compact, controlled with PWM, not terribly expensive. Works well right now for my 2x Volt Gen2 packs in parallel. The only challenge is that we're still formalizing control for it. Right now I have an el-cheapo PWM generator I manual adjust for the station, and just monitor to turn off. Hopefully I can get my Arduino control for it to work some time soon.
MattsAwesomeStuff wrote: Thu May 01, 2025 5:04 am kW. Not kWh.
Going on 24hrs no sleep. Oops
