Need help with a CHaDeMo charging sequence controller for my Lab project
muzamil
Post by muzamil »
Hello Everyone,
I am working on a lab project where we want to connect the hybrid energy storage system with the charging station. We have a CHAdeMO charging setup, and now we want to emulate the vehicle's onboard charging sequence circuit. For this, we need to connect the CHAdeMO pin with a controller on the charging side, and the other side will be connected to the Opal RT. For this setup I need a CHAdeMO controller that can work as a charging sequence circuit (IEEE std 2030.1.1-2015).
I will be thankful for your help to find this CHAdeMO charging controller. I would appreciate it if you had any links to the suppliers where I could purchase it. or is it possible to make this sequence charging circuit on a breadboard? If yes, can you please help me? How can I do that?
I apologise for this basic discussion. I am new to this field, and this is my first project with a CHAdeMO controller and vehicle charging.
Thank you very much
