GS450h smoothness at very low speed.
How smooth is your GS450h at slow speed?
Very smooth
2
29%
Mostly smooth
0
No votes
Not so smooth
2
29%
Not smooth
3
43%
Total votes: 7
Has thanked: 82 times
Been thanked: 422 times
How's everyones GS450h perform at walking pace? For example in crawling traffic?
Mine can be quite jerky but very smooth once moving and I've trying to address.
My setup is:
GS450h with ZombieVerter 1.21 release.
I use the blended motor option, but seems the same with MG1+MG2, MG1 only, MG2 only and blended.
High gear only, it get the same performance in low too.
Just trying to get some data and thoughts together.
barracuda816
Has thanked: 45 times
Been thanked: 22 times
Re: GS450h smoothness at very low speed.
Post by barracuda816 »
It's a Shame to hear this. Are you finding any difference since implementing the "creep mode", and do you have any regen functions. I forget, what inverter are you using?
Also was Andy having the same problem with the L210?
I'm using the 450h inverter, using the sync serial comms. I do have regen, but it's not active at this low of RPM. I'm still experimenting with creep, but I'm not a fan of it, but maybe it'll help diagnose. It seems to not like low torque requests. If I set off a bit quicker its smoother.
Not sure about the L210. Just trying to get an idea of how many of us has this.
Has thanked: 134 times
Been thanked: 335 times
Bigpie wrote: Wed Apr 23, 2025 10:18 am I'm using the 450h inverter, using the sync serial comms. I do have regen, but it's not active at this low of RPM. I'm still experimenting with creep, but I'm not a fan of it, but maybe it'll help diagnose. It seems to not like low torque requests. If I set off a bit quicker its smoother.
Maybe apply good shielding for resolver wires? Try to connect it on one end and then on both ends. Pick the one that works best...
Communication lines between inverter and gearbox too...
What i learned with peugeot sensor wiring was that any aux power lines running parallel to sensors could cause spikes and i kept them well clear by at least 30cm apart from signal wires.
Also gearbox and inverter casings should be connected to chassis by a good size wire - 6mm2 minimum.
I'll double check the earthing situation, but just looking for everyone's experience.
PetersonOctavius
Has thanked: 67 times
Been thanked: 18 times
Post by PetersonOctavius »
gs450h driven by a toyota camry inverter, zombie v2.22A. on the web interface GS300H is chosen under inverter
it drives smooth at low speeds
