MG Charger Hacking
Has thanked: 75 times
Been thanked: 696 times
MG Charger Hacking
Ok, MG on board chargers. So far I have looked at two models that as far as I know are from 2019 and 2022 model year ZS vehicles. Both are capable of 6.6kw. The Gen1 as I'm calling it is a charger only and uses very simple CAN commands as detailed on the Github repo :
https://github.com/damienmaguire/MG-EV-Charger
The Gen2 has a 6.6kw charger, 2kw DCDC converter and 3.6kw V2L capability. A 3 phase and sinlge phase version of the latter is available. As far as I kn ow Gen1 is single phase only.
Aim of the game will be to add these to Zombieverter VCU in the future. I have a Gen2 installed in the Red Arrow (E36) so this will probably be the first put through its paces.
Some videos :
manny
Has thanked: 38 times
Been thanked: 125 times
Re: MG Charger Hacking
Post by manny »
Have one of the single phase MG chargers in my Saxo project (ZS10BC6600A).
Have done some testing with integration with Zombie. Did this the lazy way by changing the existing files for the outlander charger.
Also changed and improved the DBC file. The MG_VZ charger.txt is the DBC just change the .txt to .dbc
outlanderCharger files are the file I mangled to control the MG ZS charger. Use at your own risk :)
outlanderCharger_h.txt
(1.86 KiB) Downloaded 508 times
outlanderCharger_cpp.txt
(5.91 KiB) Downloaded 485 times
MG_VZ charger.txt
(4.71 KiB) Downloaded 504 times
  • PSA battery (50kWh)
  • Zombie VCU
LRBen
Has thanked: 86 times
Been thanked: 252 times
Post by LRBen »
I've got a Gen 2 charger from an MG5, part number EP2CCU6625A in my current project.
A slight difference in the pinout compared to the V2Lchargerpinout.png on the github, actually only figured it thanks to Damien's video. Just the pins of the hybrid can are difference. The charging wake up input also seems to have no effect. The pinout I have working is as follows:
A3: CP
A4: PT can H
B2: charge port temp +
B3: PP
B4: PT can L
D2: Charge port temp -
D3: 12v wake up
G2: hybrid Can H
G4: Gnd
H1: 12v
H2: hybrid Can L
I have the DC-DC working via canlog playbacks. Working on a test zombie modules now for that. No charging yet, but I also have a FOCCCI in this setup so there are some extra variables at play that I need to nail down first.
Currently one can ID clash between the MG logs and FOCCCI, with the can ID 0x358. In the MG logs this is all 00s so hopefully it is not required for the charger, but will test more and report back.
LRBen
Post by LRBen »
So I've made a bit of progress with this. I have DC-DC running on a zombie test module, I also have charging running with fixed frames, these frames are in the current zombie test module but I haven't done any charge start code yet so it's not 100% functional.
The DC-DC needs only a couple of bytes to change. It is important for these bytes to change back when zombie shuts down to allow the charger to reset, otherwise it sometimes requires a 12v cycle to work again.
        bytes[0] = 0x06;
        bytes[1] = 0xA0;
        bytes[2] = 0x26; //26 for on, 06 for off
        bytes[3] = 0x00;
        bytes[4] = 0x00;
        bytes[5] = 0x00;
        bytes[6] = 0x00;
        bytes[7] = 0x7F;
        can->Send(0x19C, (uint32_t*)bytes, 8);
        bytes[0] = 0x00;
        bytes[1] = 0x03; // 01 is stand by, 03 is driving, 06 is AC charging, 07 is CCS charging
        bytes[2] = 0x00;
        bytes[3] = 0x00;
        bytes[4] = 0x00;
        bytes[5] = 0x00;
        bytes[6] = 0x20; // 20 to wake up charger.
        bytes[7] = 0x00;
        can->Send(0x297, (uint32_t*)bytes, 8); // 297 is BMS state
        bytes[0] = 0x0E; //0E to wake up
        bytes[1] = 0x00;
        bytes[2] = 0x00;
        bytes[3] = 0x00;
        bytes[4] = 0x00;
        bytes[5] = 0x00;
        bytes[6] = 0x20;
        bytes[7] = 0x00;
        can->Send(0x1F1, (uint32_t*)bytes, 8);
For the charging you need these frames:
Then to reset you need to change that to this:
It is mostly just 297, and 29C that change I think. In here is also the DC-DC messages.
I haven't found any current ramp so far, these charging messages were taken from a low current granny plug charging log. But if I used them when plugged into a 6kW wall charger I get 6kW of charging. I am guessing somewhere in here are BMS charge current limits, probably 29B or 29C.
My github repo for the test module is here:
https://github.com/SomersetEV/Stm32-vcu/tree/MGgen2V2L
I need to add a charge start and stop code, so it's definitely not functional right now.
One issue I have found is that it doesn't like the CP spoofing from Zombie outputs. Only works with the real thing as far as I have experienced. This does make integration with FOCCCI a little tricky.
I have attempted to get V2L working but so far no luck there.
LRBen
Post by LRBen »
Added PP detect on the zombie module and today charged with zombie controlled charger for the first time. Updated the github with this code.
It only starts with PP detect, still no current ramp or stop mechanism. For this current implementation I used the wall charger to stop charging, then when I unplugged the zombie shut down.
Canbus logs of this attached for anyone who is interested.
On the canbus is:
Zombie
MG charger
Leaf inverter
Isa shunt
FOCCCI
The events the log captures
Zombie in off mode
EVSE plugged in
zombie enters charge mode via precharge and starts charging, ramping up to 6kW
EVSE stops charge, I assume with a CP disconnect or something along those lines
I unplug the EVSE
Zombie moves to OFF mode and opens contactors
MG charger, zombie, wake on PP, 6kW charger, switch off at charger, unplug.csv
(1.68 MiB) Downloaded 139 times
LRBen
Post by LRBen »
Had another play with the charger today.
Managed to cut down the messages required for charging to the following:
I have yet to move this to the zombie test module to confirm. But it's looking promising so far.
I also think I have found the current limit message in 0x29C, the last two bytes.
Has thanked: 454 times
Been thanked: 1771 times
LRBen wrote: Sat Jun 07, 2025 6:26 pm
The one that reads 0x57? So 87 decimal. Does it charge with 8.7A right now?
Or 0x5700 22272 mA?
LRBen
Post by LRBen »
johu wrote: Sun Jun 08, 2025 8:24 pm The one that reads 0x57? So 87 decimal. Does it charge with 8.7A right now?
Or 0x5700 22272 mA?
I have some rather vague data from my notes. At the time I could only get AC current as that was easily read from the socket meter.
When everything else was 00, byte 6 would have the following effect on the charge current.
0x47 is 1 amp AC, 0x48 is 2 amps AC, 0x49 is at least 8 amps AC as it maxed out the 2kW EVSE I was charging from at the time. Changing byte 7 did have some smaller effects, but I couldn't get anything uniform.
Damien has suggested it's a value spread across bytes 6 and 7 and I think he is correct. I just need to do some more testing to verify. I'll also try to get some DC amp data as well.
With it set to 0x57 as it has been so far for testing it would max out the MG charger from a 7kW wall EVSE.
Has thanked: 89 times
Been thanked: 481 times
Does the gen2 care if anything is on the PP pin?
LRBen
Post by LRBen »
Bigpie wrote: Wed Jun 25, 2025 3:58 pm Does the gen2 care if anything is on the PP pin?
Yes I had to connect PP to the charge socket to get it to work.
You tested if it'll just DCDC with the PP resistor there? I connect PP to FOCCCI
LRBen
Post by LRBen »
Bigpie wrote: Thu Jun 26, 2025 10:22 am You tested if it'll just DCDC with the PP resistor there? I connect PP to FOCCCI
I am pretty sure it will DC-DC fine without the CP and PP connected. I've been moving CP and PP to different places during testing and the DC-DC always seems to kick in.
My current setup has PP going to the charger and CP on a switch so I can quickly switched CP over to FOCCCI for the one time I want to use CCS.
I think PP is the easier one to spoof though, but I've kept it going to the charger as the V2L adaptors look to have a set resistance on PP.
whereswally606
Post by whereswally606 »
I've taken the plunge an bought 2 2020 (gen1) obcs from an online breaker. Due to some initial shenanigans I've lucked out and they are now sending me a third as connectors have damage on one.
My plan is to upgrade the 1ph charger on my e-nv200 to 3ph. I may use the bonus one to augment my 2011 leaf too.
Help might be required to get this all working seamlessly. I've a 24kwh env200 battery for storage left over from a swap to a 40kwh so I should be able to get this test on a bench before trying on the van. My friend also have a rotary inverter so I shouldn't need to risk any infrastructure on the street. Thanks in advance for any help.
Have you tied the 2 can buses together?
whereswally606
Not done anything yet Jamie except buy the bits.
I have 2 mgzs obc 1ph
One have a broken ac port
https://www.mouser.co.uk/ProductDetail/ ... TLgQ%3D%3D
Not paying £50 to replace it. I will either use the thingy verse part to put an m25 grommit on or I've request the ECAD part and might get it 3d printed in a strong high temp plastic. If anyone has this part spare from a broken mg zs obc teardown then I'd buy it off them.
I also have the full harness and junction box plus CCS port
I also go given an mg5 inverter with v2l so that will hopefully go into my 2011 leaf. But first I need to get things tested outside the cars.
whereswally606
ECAD attempt from mouser failed next stop thingyverse unless folk here have a spare and matching plug.
Not sure about the ZS charger, but the MG5 it's not easy to remove the connector and replace with a grommet, they're soldered to the board.
whereswally606
Mg5 obc connector flange is OK. Just the zs one on one of. I have a full loom for the zs but I could do with a 2nd or replace for custom connector. Will need an mg5 loom too or the connectors
Mg5 connectors were a pain to get. I used taobao and super buy to get them. Was tempted to get a few sets and stick em in classifieds
whereswally606
Just phoned mouser thinking the £46 price tag was for 224 factory pack of flanges. Nope it was for one. Wow.
Might do the thingyverse thing. Might have a look at your Chinese website suggestion
whereswally606
Couldn't find any mg zs connectors on superbuy, bigpie do you have links to the mg5 ones you bought or do you have spares to sell?
It's pretty convoluted, you give super buy the link to what you want a Taobao, then use international bank transfer to an account, then fill in the form on superbuy and wait for your account to be topped up, then they buy them from Taobao and forward on to you once they've been delivered to them.
https://www.superbuy.com/en/page/buy/?u ... .N.685a904
https://www.superbuy.com/en/page/buy/?u ... .N.757f5bf
I only ordered 1 of each as I wasn't confident I'd ever see them. I can order more, but I don't have spares.
whereswally606
Thanks for the links Jamie, I bought two of the DC and one of the ac for the mg5 charger from your superbuy links. Haven't yet managed to make myself a taobao account as my Chinese is weak and thus searching for the mg zs charger parts is pretty damn impossible.
Has thanked: 264 times
Been thanked: 717 times
On the Gen 2 if you do not have the DCDC working, check the wake signal line is to the right pin.
More accurately, if you only have DCDC working during charging, check it.
