Lexus GS450h Inverter DC DC Converter Delete
Has thanked: 628 times
Been thanked: 1606 times
hope some of you find this useful, I did not want to burry it in my truck build thread or any of the deep inverter support threads
please post your ideas of what you would use this empty cavity for
Re: Lexus GS450h Inverter DC DC Converter Delete
Top Tip: Three keys to a successful EV conversion are:
  • Networking
  • Networking
  • Networking
these high voltage AC motor wires really do not have to be cut and with the right amount of WD-40 and handrolics they eventually do come right out
Has thanked: 475 times
Been thanked: 307 times
Post by MattsAwesomeStuff »
That doesn't look like networking. That looks like Artur doing the work for you while you hold the camera and distract him!
MattsAwesomeStuff wrote: Wed Apr 02, 2025 9:09 pm That doesn't look like networking. That looks like Artur doing the work for you while you hold the camera and distract him!
hey, let's not split hairs here
TongueTester
Been thanked: 7 times
Post by TongueTester »
Greg,
I thoroughly enjoyed the video, you have a way of making these topics accessible to us common folk. I have my fingers crossed that you do a tear down video of the gen 4 inverter.
Thanks Peter
TongueTester wrote: Wed Apr 23, 2025 10:56 am Greg,
Thanks Peter
thank you for the kind words Peter, and ...
marcexec
Has thanked: 1039 times
Been thanked: 111 times
Post by marcexec »
Brilliant video, appreciate the "deep dive". Could you maybe add some subtitles/closed captions for the segment without audio? It felt important, at least at the time. Or add something to the description instead if that's easier?
My Suzuki RF400 build @ES
Honda IMA & Lebowski howto
nino500
Has thanked: 10 times
Post by nino500 »
Gregski wrote: Wed Apr 02, 2025 2:29 pm please post your ideas of what you would use this empty cavity for
Do you think you could hide a Zombie in there?
Or maybe just a bunch of relays and fuses for new conversion related circuits like EPS and brake pump etc.?
i do not recommend gutting the dc-dc as you loose an important spot value invudc aka inverter voltage reading
maciek16c
Been thanked: 12 times
Post by maciek16c »
That's because the MTH data is being interpreted incorrectly. The "dc_bus_voltage", currently treated as the drive voltage, actually represents the DC-DC voltage (288V), while the inverter voltage (650V) is stored in the adjacent bytes.
Has thanked: 91 times
Been thanked: 517 times
I think the fix for that will be in the next release.
nino500
Post by nino500 »
I have a question arising from this teardown:
As we're putting the battery connection directly into the inverter on the terminals behind the plastic cover, doesn't the existence of those thin busbars mean that the battery voltage is also applied to the DC-DC?
I thought, applying battery voltage there would blow the unit. Are we deleting the busbars or leaving them in?
Thanks.
nino500
Post by nino500 »
nino500 wrote: Fri Apr 24, 2026 4:39 pm I have a question arising from this teardown:
Thanks.
Ok. Just rewatched Damien's connection video again (must be 4 times now but it's like a good movie; you notice things you didn't get from the last watch every time).
I see now that the busbars remain in place and they're not a direct parallel connection to the boost converter input.
