Rolls Royce with a Tesla Drivetrain
Hank
Post by Hank »
Someone had to do it, so I guess I'll be the idiot to pull it off.
[*]One perfectly good 78 Silver Wraith (check)
[*]One brand new Tesla Sport LDU (check)
[*]One fabulously designed open sourced control board (check)
What could possibly go wrong?
Kevin Sharpe
Been thanked: 8 times
Re: Rolls Royce with a Tesla Drivetrain
Post by Kevin Sharpe »
Cool project :)
mattndex@gmail.com
Post by mattndex@gmail.com »
This is going to be interesting.
clanger9
Post by clanger9 »
Loving this one! 8-)
Bentto
Post by Bentto »
Yes!!
Hank
Post by Hank »
OK, so I'm starting the shopping spree....
I have the Car, the LDU, and Damien's controller.
I purchased the 23 pin 12v control harness, and the 4 wire plug/harness.
I'm going to be using Tesla S batteries, full pack.
Step one will be to build out my test bench, and therefore my precharge circuits etc.
I need a bit of advice on contactor models, resistors, and whatnot. I don't want to gold plate this thing, but I'm not looking to cut corners either.
Ev-west has a few contactors, they look very similar to me at first glance. Gigavac GV200 in 3 varieties for instance....couldn't even begin to tell which features matter for my application. Are there better ones out there? I don't know.
Any help would be greatly appreciated.
57 Chevy
Post by 57 Chevy »
Hank wrote: Sun Mar 22, 2020 1:16 am
Cool project!
The battery is about 600kg and you may have to cut out and remake a lot of the floor to fit it in. It'll quite likely too wide for the Rolls too, S is a massive car. You may be required to keep the GVM under the max for the stock Rolls so bear in mind you could possibly lose the rear seat and passengers if you want a big battery. Good thing is they have the contactors and pyro fuse built in so plug in and you are in business with a bit of CAN knowledge. The connectors are special so you'll have to buy the rear HV junction box plus the LV connectors off the car loom to get the comms and power going
I can get you measurements if you need, picked up this one on the weekend to use the LDU along with another one in an awd 57 Chevy
Main piece of advice I'd give you is don't cut anything off until you are fully committed financially and emotionally to the project, otherwise you run the risk of having an unusable/unsaleable car if your situation changes in a year or two and you find you don't have the resources to finish it.
Kevin Sharpe
Hank wrote: Sun Mar 22, 2020 1:16 am I'm going to be using Tesla S batteries, full pack.
A Model S pack 3D Model is available if you want to check some dimensions;
viewtopic.php?f=10&t=123&p=8153#p8153
However, I'd recommend using the Model 3 pack which is much smaller, lighter, and cheaper :)
Hank
Post by Hank »
Sorry, I was unclear there. I didnt mean I was going to literally use the Tesla pack itself, but that I would be purchasing a full set of the 16 or so batteries that the Tesla comes with, and using them to build my own custom pack.
Apologies.
Igor
Post by Igor »
57 Chevy wrote: Sun Mar 22, 2020 4:54 am Image
I have nothing to add. Except to say that this pic is amazing!
deaglan
Post by deaglan »
Have you a plan for the hydraulics?
Brake and ride height system run off cam-driven pumps, and it’s a specific fluid, so can’t easily replicate.
There’s a good overview here (https://www.rrsilvershadow.com/Emenu/hydr.htm)
I think if you did put a full Tesla battery pack in the car, it might be the first EV conversion to increase range!
Hank
Post by Hank »
deaglan wrote: Sun Apr 19, 2020 12:17 am Have you a plan for the hydraulics?
Yes...I have done a ton of research on these cars. One of the reasons I bought it is because other people fear the hydraulics, which makes them a good deal if you don't care about keeping it stock.....which clearly isn't an issue for me.
Hank
Post by Hank »
So one of the things that I like about this project is I can build out and test my new drive train without needing to destroy my perfectly running car in the process. So for the past few weeks, I have been shopping, and assembling the stuff I would need to setup a solid test bench. Hat tip to Roadstercycle for his YouTube video of his bench test setup, it gave me a real good idea of what I needed to do to get a bare bone system up and running.
One of the best finds was a 23-pin harness that was only around $50 online somewhere. Saved a bunch of time not having to build my own, especially since it was just going to exist on my bench.
Enjoy the wire porn....
Labels are a must
Labels are a must
Easy distribution and a tidy workspace
mmmm....TOYS!
mmmm....TOYS!
ZooKeeper
Post by ZooKeeper »
Hank wrote: Sat Mar 21, 2020 2:14 pm Someone had to do it, so I guess I'll be the idiot to pull it off.
Let me be the first to challenge the "idiot" idea; Loon? Maybe.
And while not 100% sure on this, I doubt the world have ever seen a "perfectly good 78 Silver Wraith".. LoL
ZooKeeper
Post by ZooKeeper »
deaglan wrote: Sun Apr 19, 2020 12:17 am I think if you did put a full Tesla battery pack in the car, it might be the first EV conversion to increase range!
OMG, I nearly p!ssed myself!!!
Hank
Post by Hank »
Got the motor on the stand, swapped the board, plugged in the wiring harness, got precharge contactor behavior as it should be, logged in to wifi and saw the web page.
Not a bad days work.
Bentto
Post by Bentto »
Very impressive!
btw, what labelprinter are you using? Looks nice.
Hank
Post by Hank »
Thanks, the label maker is a Rhino 4200 by Dymo. Bought it on Amazon for around $60.
https://www.amazon.com/gp/product/B005M ... UTF8&psc=1
Hank
Post by Hank »
Found a bit of rust in the floor after removing the engine....things escalated quickly from there.
celeron55
Has thanked: 38 times
Been thanked: 136 times
Post by celeron55 »
Looks decent, considering the age. :-)
Maker_of_Things
Post by Maker_of_Things »
This has just reminded me of this Rolls Royce Tesla.
Alfred Chow - Maker of Things.
My Skoda Octavia conversion blog
Hank
Post by Hank »
Passenger floor pan removed, new floor pan loosely fitted. Should get me through another 40 years.
