'63 VW Transporter - EM57 Powered.
jerrykco
Has thanked: 252 times
Been thanked: 43 times
Post by jerrykco »
'63 VW Transporter - EM57 Powered. [WIP]
This is my new project. Finally wrapping up the '70 MGB Roadster - 2015 Leaf EM57 powered and we learned a lot!
So far just collecting parts.
● A new wire harness is on the way.
● We have the full stack Leaf EM57 motor already.
I am not sure it will fit but I am pretty sure that the Inverter and motor will.
● We just ordered a KIA EV6 / HYUNDAI Ioniq 5 EV 77KWH 800v battery.
New w/0 miles Came from cars damaged in transit.
We plan to drop the voltage in half placing half the 32 modules in parallel.
● Battery Storage
Under the bed where the gas tank is & under the rear bench seat. That is our working theory anyway.
● We plan on using the Brat VW adapter between the EM57 and the transmission.
● VW bus status.
Body panels that were rusted were replaced 5-10 years ago followed by a poor paint job.
Paint and body putty needs to be removed.
We are planning on stripping it (bead blasting) inside and out then sanding it and primed.
Followed by a new paint job before starting on the conversion.
● Questions:
1. Has anyone hacked the BMS for this battery pack?
2. Any recommendations for a VCU?
3. How about Gauges? Any ideas there?
Speedometer should still work off the transmission.
I would like an indicator for the battery condition like a fuel guage.
Love to hear your ideas and thoughts.
Jerry Kauffman
jerryk48 at gmail dot com
jerrykco
Re: '63 VW Transporter - EM57 Powered.
Post by jerrykco »
Now for some Pictures:
Rescuing the Transporter:
The Battery
The EM57
Jerry Kauffman
Has thanked: 246 times
Been thanked: 469 times
jerrykco wrote: Sun Mar 16, 2025 1:27 pm .
● Questions:
I am using the a leaf motor and half of one of these batteries.
Zombieverter for the stack
The bms uses a max MAX17845 chipset
Threads: viewtopic.php?t=1179
viewtopic.php?t=2243
Commercial bms master:
https://wdrautomatisering.nl/shop/gatew ... 1-gateway/
jerrykco
Post by jerrykco »
Bratitude wrote: Sun Mar 16, 2025 2:06 pm I am using the a leaf motor and half of one of these batteries.
What are you using for the BMS?
Are you cooling the batteries? (I read some concerns in the topics you shared).
Jerry Kauffman
jerrykco wrote: Sun Mar 16, 2025 3:33 pm What are you using for the BMS?
I don’t have the battery assembled yet, but for now mounting them on a 8mm aluminum plate, which I will replace with a liquid cooling plate later on.
The stock bms slaves and the parts referenced in the threads. Likely will purchase the bms master I linked.
I will be updating my 720 build thread in a few weeks with battery progress
ianlighting
Has thanked: 258 times
Been thanked: 189 times
Post by ianlighting »
Hurrah! Another VW!
Seen my T2 build? There’s photos I’ve put up over the last 2 days that give you some pointers on how you can arrange the Leaf stack. Mine’s a 74, so I’m guessing I’ve got a bit more space to play with.
The engine bay had plenty of space in terms of volume, but it was really hard to find a way to use it to home all the Leaf stuff. What I came up with is the only solution that worked for me. Separated the PDM, and rotated it 90deg so it could sit slightly lower in the fuel tank space. It’s tight though, and the design on your earlier model could be different if you’re unlucky. Be interesting to see if you find another way to do it.
Also, the later T2’s had an engine inspection hatch. This has really been invaluable for me. Mounting the motor is ok, Brat adaptors are good, but for all the other wiring and coolant stuff I think i would have found it impossible without being able to look down on it and get my hands in.
viewtopic.php?t=4943&start=100
For a different take on things check out Cera’s build on her T2. Using motor direct to axle. More complex to support, but gives you more space to play with I think.
Good luck!
jerrykco
Post by jerrykco »
ianlighting wrote: Sun Mar 16, 2025 4:13 pm Seen my T2 build? There’s photos I’ve put up over the last 2 days that give you some pointers on how you can arrange the Leaf stack. Mine’s a 74, so I’m guessing I’ve got a bit more space to play with.
Checking them out, now!
Jerry Kauffman
jerrykco
Post by jerrykco »
Well this is discouraging.
I tried to order the Zombieverter on http://www.evbmw.com/index.php/evbmw-webshop/vcu-boards
I get this message:
Shopping Cart
Your shopping cart is empty!
Jerry Kauffman
Has thanked: 91 times
Been thanked: 517 times
It seems to be working for me. Pressing "Add to cart" and then "Checkout"
At which stage are you having issue? I notice you're not on the https site https://www.evbmw.com/index.php/evbmw-w ... vcu-boards this is likely your issue.
jerrykco
Post by jerrykco »
Bigpie wrote: Wed Jun 11, 2025 1:08 pm It seems to be working for me. Pressing "Add to cart" and then "Checkout"
Thanks Bigpie!
I used your link and it worked. Whoooo Whooooo! It's ordered!
Jerry Kauffman
jerrykco
[WIP] Re: '63 VW Transporter - EM57 Powered.
Post by jerrykco »
Update: I ordered Zombiverter an June 11. I haven't received a confirmation email as of today June 14th. Is that normal?
I also ordered and received from Aliexpress https://www.aliexpress.us/item/2255801027254586.html the metal case and wire harness for the card.
Questions:
1) I think I understand but want to confirm: My first EV build used the OI board with the EM57. This time I want to use the Zombi and avoid the disassembly of the stack. Confirming that I do not need the OI board and can use the native board and control the Leaf Stack w/ the Zombi?
2) Also I want to control the Otrion BMS with Zombi. Am I missing anything?
3) Is there a preferred accelerator pedal?
Jerry Kauffman
Has thanked: 545 times
Been thanked: 153 times
Post by Jacobsmess »
1. Yes zombie will work with the leaf stack over CAN
2. I think Orion would need to be setup using CAN mapping. If you use the Orion to send messages on the same IDs as SimpBMS this should work but might be worth double checking
3. Any accelerator that uses a potentiometer, preferably a dual pot pedal for redundancy.
jerrykco
Re: '63 VW Transporter - EM57 Powered. [WIP]
Post by jerrykco »
Oh boy, zombie arrived yesterday.....
Thanks Damien!
Jerry Kauffman
jerrykco
[WIP] '63 VW Transporter - EM57 Powered.
Post by jerrykco »
Got the Ioniq5 Battery disassembled.
It's actually a masterpiece of mechanical engineering!
My current thinking is 16 of the 32 modules (38.5KWH). But I will look at getting all 32 for 77 KWH. This would be preferred but will be substantially more difficult.
Jerry Kauffman
jerrykco
Post by jerrykco »
For converting Classic Cars with Analog gauges to EV, has anyone looked into Displays that can lurk on the can bus intercept specific messages for updating a dashboard add on display?
I found this on Alibaba. It has a GUI development application and has an optional STM32 processor available for the backside electronics that has a CAN bus interface.
https://www.alibaba.com/product-detail/ ... 57937.html $210 shipped from China.
I would be interested in peoples thoughts on this or other alternatives.
If I can get it working, I would be glad to share code.
Jerry Kauffman
Proton
Has thanked: 227 times
Been thanked: 57 times
Post by Proton »
If you like how it looks you can use this solution or you can modify it. It uses CAN messages.
If you can make it better you can re-post the code.
viewtopic.php?p=83713#p83713
Note with the battery modules, do not stack them on top of each other, the rivets will indent the pouch cells (as they are exposed on the bottom) and will damage them
cajamatt
Has thanked: 43 times
Been thanked: 18 times
Post by cajamatt »
Bratitude wrote: Fri Jun 27, 2025 1:40 am Note with the battery modules, do not stack them on top of each other, the rivets will indent the pouch cells (as they are exposed on the bottom) and will damage them
i found this out the hard way... not by stacking but by scraping the thermal putty off with a pick. thought it was aluminum but turns out its very thin plastic. i might have put a tiny hole in the pouch and idk how to tell if i totalled the module by doing so.
jerrykco
Post by jerrykco »
I am restacking them with a sheet of plywood between them. Thanks for the heads-up!
Jerry Kauffman
cajamatt wrote: Fri Jun 27, 2025 4:32 pm i found this out the hard way... not by stacking but by scraping the thermal putty off with a pick. thought it was aluminum but turns out its very thin plastic. i might have put a tiny hole in the pouch and idk how to tell if i totalled the module by doing so.
Consider that module unsafe to use in a pack. If it has a tr event, the whole pack is going with it
Has thanked: 328 times
Been thanked: 847 times
jerrykco wrote: Fri Jun 27, 2025 5:22 pm I am restacking them with a sheet of plywood between them.
No. do not do that in a vehicle.
jerrykco
Post by jerrykco »
tom91 wrote: Sat Jun 28, 2025 10:24 am No. do not do that in a vehicle.
Right, Tom.
This is only for storage on the floor of the shop and is temporary.
My build will include a custom aluminum battery box to be designed to fit under the back seat in the crew cab.
Storage in the shop and the damage to one of the modules, damn!
Jerry Kauffman
jerrykco
Post by jerrykco »
Progress update:
We cleaned up the shop area and made room for the VW. Got it moved into the shop after removing all the parts from the Ioniq 5 battery.
Next steps:
- Remove everything from the body of the VW.
- Strip it using a sand blaster and Green Diamond media
- Prime it with Roll-On Epoxy Primer from Eastwood
Then have it professionally painted.
In the mean time I will complete the Zombieverter (watchching Damien's Videos and reading instructions)
Build a battery box
Figure out how to mount the Leaf ( looking at how others did it).
And doing a bench test for spinning the motor.
Jerry Kauffman
jerrykco wrote: Sat Jun 28, 2025 3:04 pm Storage in the shop and the damage to one of the modules, damn!
that sucks, you could possibly harvest the good cells from the module for other purposes. But I would just slowly drain that cell to 0, and do it in an isolated area. Just reduces the chance of anything happening
ianlighting
You might want to take a look at your gearbox before you start getting too far into the build. I’m guessing you’ll be leaving it in 3rd gear for driving, so that makes you dependant on that gear in the transmission. Probably be fine, but if it’s high mileage it’s something to think about. Once you start bolting a motor on, you probably won’t want to go back and strip it all down again.
