Leaf swapped Nissan 720…. On the side of the road!
P.S.Mangelsdorf
Has thanked: 290 times
Been thanked: 330 times
Re: Leaf swapped Nissan 720…. On the side of the road!
Post by P.S.Mangelsdorf »
Bratitude wrote: Sat Jan 04, 2025 2:22 am
The local yard has a Prius power steering rack for 100$.
I’ll pick it up and see what can be done. I’m not okay with cutting and splicing up the 720 column to make it work.
A electric column would make for a lighter, and cleaner install.
Hot Rod did an article on the Prius column, in case you hadn't seen it:
https://www.hotrod.com/how-to/150-elect ... -delivers/
Has thanked: 222 times
Been thanked: 413 times
Power steering:
The truck has a hydraulic steering box.
There’s 2 options for power steering:
Electric power steering pump to feed hydraulic pressure to the box.
Or electric power steering column.
A epas pump is the simplest install, just plumb it in and good to go.
Cons are I’m adding weight as the pump is heavy
And there’s hydraulic fluid!
And it’s noisy
Yuck!
Epas column would be quiet, more efficient , and not add anything into the engine bay.
Con’s are lots of custom fab work, which is tricky as I’m am not allowing any of the original trucks column to be cut or welded. this is out of safety and keeping everything bolt on:)
there’s a rag joint just outside the fire wall… so it may be possible to retro fit a Prius rack with some off the shelf couplers.
but picked up an old Mazda epas pump for 80$ cad.
Heres the epas pump and the original line + pump from the truck.
epas pump pressure outlet is a m14 jis banjo fitting
The trucks original power steering lines have a bigger jic banjo. Close but no cigar.
3 fittings later we have connections!
M14 banjo jis -> female x female jis union ->jis x jic union
simple, no expensive custom hoses, and all off the shelf parts!
okay now mount it and work on controlling it. its not as straightforward as some of the other pumps like the volvo or ampera. it has 3 connectors, power, can, and analog steering angle.
luckly some one has done the heavy lifting already https://github.com/shifty35/mazda3-ehps-control
code just needs a bit of clean up and good to go.
what i have distilled down so far
#include <mcp_can_dfs.h>
#include <mcp_can.h>
#include <SPI.h>
#include <Arduino.h>
const int STEERING_ANGLE_PIN_A = 4;
const int STEERING_ANGLE_PIN_B = 5;
const int INT_PUMP = 6;
const int SPI_CS_PUMP = 8;
MCP_CAN can_pump(SPI_CS_PUMP);
short int previous_steering_angle = 0;
short int current_steering_angle = 0;
short int target_steering_angle = 0;
bool current_steering_angle_valid = false;
long last_steering_time = 0;
// Globals for CANBUS debug / testing
uint32_t counter = 0;
void convert_201_values(uint8_t buf[]) {
    // RPM = uint16_t(bytes 0, 1) * 4
    uint16_t engine_speed = ((buf[0] * 256) + buf[1]) / 4;
    // Speed in KM/hr = (uint16_t(bytes 4. 5) + 100) * 100
    uint16_t vehicle_speed = (((buf[4] * 256) + buf[5]) / 100) - 100;
    // Mazda 3 pump expects RPM as raw bytes, no scalar like MX5
    // Mazda 3 pump expects km/hr*100, no 100 km offset like MX5
    vehicle_speed *= 100;
    // Write modified values back into buffer
    buf[0] = engine_speed / 256;
    buf[1] = engine_speed % 256;
    buf[4] = vehicle_speed / 256;
    buf[5] = vehicle_speed % 256;
// current_steering_angle and target_steering_angle are doubled to allow for .5* resolution without floating point conversion.
void update_steering_outputs() {
  // Don't update pin outputs too frequently
  if (micros() - last_steering_time < 500) return;
  if (target_steering_angle > current_steering_angle) {
     current_steering_angle++;
  } else if (target_steering_angle < current_steering_angle) {
     current_steering_angle--;
  digitalWrite(STEERING_ANGLE_PIN_A, abs((current_steering_angle / 6) % 2));
  digitalWrite(STEERING_ANGLE_PIN_B, abs((((current_steering_angle + 3 )/ 6)% 2)));
  last_steering_time = micros();
void setup()
    // Setup digital outputs for steering angle sensor
    pinMode(STEERING_ANGLE_PIN_A, OUTPUT);
    pinMode(STEERING_ANGLE_PIN_B, OUTPUT);
    digitalWrite(STEERING_ANGLE_PIN_A, LOW);
    digitalWrite(STEERING_ANGLE_PIN_B, LOW);
    uint8_t ret;
    ret = can_pump.begin(MCP_ANY, 13, MCP_8MHZ);
    if (ret == CAN_OK)
        can_pump.setMode(MCP_NORMAL);
// Main program loop.  Poll both CAN networks.  If 0x201 received from vehicle network, modify and rebroadcast to pump network.
void loop()
    update_steering_outputs();
    uint32_t id;
    uint8_t len;
    uint8_t buf[24];
    uint8_t ret;
    // Check interrupt pin for vehicle CAN
        // Check if 0x201 ID
        if (id == 0x201) {
            // 0x201 - modify and rebroadcast to pump
        } else if (id == 0x081) {
            // Convert from steering angle message format to degrees
            int16_t steering_angle;
            unsigned char *ip = (unsigned char *) &steering_angle;
            ip[0] = buf[3];
            ip[1] = buf[2];
            uint16_t u_steering_angle = (steering_angle * 10 ) + 1600;
            ip = (unsigned char *) &u_steering_angle;
            // We initialize steering angle to zero.  This conditional makes sure there aren't any wild jumps in output from the first steering message.
            if (!current_steering_angle_valid) {
              current_steering_angle_valid = true;
              current_steering_angle = steering_angle * 2;
              previous_steering_angle = current_steering_angle;
            // Drive outputs for early version Mazda 3 pump (pre 2009)
            target_steering_angle = steering_angle * 2;
Has thanked: 480 times
Been thanked: 137 times
Post by Jacobsmess »
Bratitude wrote: Sun Jan 12, 2025 6:12 pm It has 3 connectors, power, can, and analog steering angle.
So does this have partial load no load pwm functions? Or just on like they were on older ICE vehicles?
Jacobsmess wrote: Mon Jan 13, 2025 9:27 am So does this have partial load no load pwm functions? Or just on like they were on older ICE vehicles?
Depending on engine rpm and steering angle it’ll vary pump speed
pickd up a 2017 camery epas column for 100$
and.....
its a direct bolt in to the pedal box.
crazy!
the controller box is directly bolted to the motor so i removed it for more space. its 3phase!
motor/gearbox is a bit to big and sadly collides with a bracket on the firewall. but looks like a yaris motor unit is much smaller and should fit with the camery tilt column part.
the output of the toyota epas motors is 11/16- 36 splines, and the input shaft from the steering box has a rag joint that meets at the fire wall.
so!
with the following off the shelf connections:
11/16-36 x 3/4 dd u-joint: https://www.borgeson.com/Steel-3-4-DD-X-11-16-36.html
3/4dd shaft: https://www.borgeson.com/3-4DD-Shaft-18-Long.html
3/4dd rag joint: https://www.borgeson.com/rag-joint-flange-3-4-dd
this should result in a nonwelded steering shaft, and bolt in epas :)
random little bits:
Re sealed the inverter and tapped the inverter coolant inlet to cap it off.
Been scratching my head on how to do the driver side motor mount.
Decided to shift the stock mount over and make a bracket that ties it to the pitman arm bolts on the frame. This puts the mount right inline with the outer edge of the motor.
been busy with lots of brt ind stuff, lots of CAD work, so it’s nice to just fab stuff by hand.. with more CAD work ;)
Which resulted in:
the centre link has always been close to the motor. A common mod on these old Datsun trucks folks do when engine swapping is a “center link flip.” You drill out the tie rod tappers, and press in a new tapered insert on the other side, allowing the link to be mounted upside down, give an extra 3-4in of clearance for a motor.
This extra amount of space might allow the PDM to clear the hood..
Finished off motor mount with some goopy welds (its great that all the clean ones are hiding on the back side)
and started to assemble the prototype “pre- built” zombie unit.
P.S.Mangelsdorf
Bratitude wrote: Sat Mar 01, 2025 5:43 am with some goopy welds (its great that all the clean ones are hiding on the back side)
It always seems to happen that way, doesn't it? Nothing is more annoying.
P.S.Mangelsdorf wrote: Sat Mar 01, 2025 5:33 pm It always seems to happen that way, doesn't it? Nothing is more annoying.
grinder and paint will fix it :evil:
picked up a 110k stack, and installed a rough generic zombie harness.
along with all the other little hardware bits and clean up, truck is temporally back on the road running 2.22A, and ready for the journey over to the new shop in Victoria!
110kw in this truck is a lot....
datsun720-prams.json
(2.13 KiB) Downloaded 37 times
prams will drive the following:
-350v fully charged pack (partial volt pack,84s)
- leaf motor em57 110kw inverter
- outlander OBC (with a leaf charge port, and a 330ohm pull up resistor to 5v for ppval)
- water pump at temp set point
NO IVT SHUNT! :)
Now that I’m back in the new shop with mostly everything, I got some stainless trays cut for the zombiverter prewired interface.
After poking around to find a nice spot to mount it, I settled on the inside of the passenger fire wall.
fits behind easily removable HVAC ductting, keeps wire runs short, and is very safe from any moisture exposure.
I’ll be also able to access the obd port through the glove box!
Now can start collecting new lv connectors and build a clean harnesses for the trucks ev system
Sector7e
Has thanked: 48 times
Been thanked: 25 times
Post by Sector7e »
Bratitude wrote: Tue May 20, 2025 12:48 am picked up a 110k stack, and installed a rough generic zombie harness.
NO IVT SHUNT! :)
What is your range with that battery pack?
Sector7e wrote: Sat May 24, 2025 10:39 pm What is your range with that battery pack?
haven’t hit below 300v yet, but I’m guess 90km from what I’m seeing for a 16kWh pack
Fixing the big air scoop front end I’m sure is going to help a lot
like any mechanic truck thats forsale, you dont buy it because he's done the bare minimum! in this case, with a busy summer being outdoors and working on customer projects havent done much on the truck.
had a moment to spare and dick around with battery modules in the truck. in this case im just going to make the biggest saddle pack i can for the truck, and stuff what i can inside for now. ideally id like to get some vda355 4s3p modules and cram 55kwh in there, but ill have to wait intill a pack shows up with the modules im looking for. there is room for a secoundary rear mounted box, and could fit a full etron pack with 32 3s4p modules, but truck starts getting heavy, right now its very nimble!
the ionic modules are too long unfortunately and will collide with the already tight driveshaft (tunnel).
24 vda355 modules
all 48(96) leaf modules
my current 14kWh gen 2 volt pack
after humming and hawing about how I’m going to approach heating..... I bought a mg water heater from the uk for cheapish.
also picked up a replacement heater ducting box for the truck (as I had cut the original one up to fit a id4 heater matrix) at a pick and pull for 30$
along with other interior trim!
So that settles it, I’m going the simple route and just pluming in a coolant loop through the original heater system. Not as elegant as fitting a ptc, but it’s simple!
mg heater arrived, and wow it really is small!
Okay off to the bin of random connectors I’ve collected as I know I have a te hv plug that will fit…. And !
The outlander hv junction box has one that fits! Look at that! Just need to double check ampacity of the cables before I pull some power.
this will make for a very clean oem install as the outlander obc will also junction in to this with stock cables.
