Volvo LG Chem Battery Pack
jrubiom74
Post by jrubiom74 »
Hi All
Hopefully, someone can help me with this one...
I'm trying to control the below Battery PacK:
96 Li-Ion Cells
Cells: 288
- Li-Ion Polymer technology LG Chem P30 Cells
- Temperature : -40 to 55oC
At the end, I'm installing an external BMS (Thunderstruck BMS) because I couldn't read the boards on it.
But now I need to get the temperature of the battery.
Can anyone know how were are the thermistors on this battery? Or maybe share with me a BOM of this battery? or any way to read them?
Thank you in advance!
Jose
PD. By the way... Is there any way to attach an image here?
Been thanked: 413 times
Re: How this works
jrubiom74 wrote: Thu Feb 06, 2025 11:55 am ....
viewtopic.php?p=29156#p29156
Seems very similar to Volt gen2 battery. Cant you measure one block inside and go out and measure again to estimate its "line"?
Something similar here...
https://www.diyelectriccar.com/posts/954522/
Re: Volvo LG Chem Battery Pack
Split this to a new topic. How on earth could the "Open Tasks" intro post be chosen to be appropriate??
jrubiom74
Re: How this works
Post by jrubiom74 »
arber333 wrote: Thu Feb 06, 2025 12:16 pm viewtopic.php?p=29156#p29156
Thanks for your answer! :D
Yeah... I think that's the same!
It was split into two parts but now I have it in just 1 to get to 360V and it's also working with my Thunderstruck BMS...
But I need to measure the temperature. If I can't with the original Thermistors, which "external" thermistors would you recommend?
Thank you!
