AC charging with Foccci and Zombie, not starting
manny
Has thanked: 59 times
Been thanked: 159 times
Re: AC charging with Foccci and Zombie, not starting
Post by manny »
updated. now on 44.90.b.
with AcChargeControl set to CANremoteControlled. Behaviour is the same.
with it set to StandAlone. Foccci enabled the EVSE and after that Zombie enabled the HV.
and with a button press the HV off and EVSE off. We are getting somewhere :D
  • PSA battery (50kWh)
  • Zombie VCU
Has thanked: 330 times
Been thanked: 848 times
manny wrote: Wed Feb 05, 2025 8:59 pm We are getting somewhere
manny wrote: Wed Feb 05, 2025 8:59 pm with it set to StandAlone
So its broken for Zombie.
No idea what broke it, not really got time to look at it. It worked and now it does not.
If you got lock feedback build 80 should work with Zombie release 2.20
manny
Post by manny »
Will order a 4 wire lock motor.
But it works for now with it set to stand alone.
I will post a update when the new lock motor is installed.
Thanks for the help tom91, uhi22 and johu.
  • Zombie VCU
manny wrote: Wed Feb 05, 2025 9:19 pm update when the new lock motor is installed.
Be good to know if you can atleast get build 80 working to have a starting point to investigate further.
uhi22
Has thanked: 245 times
Been thanked: 684 times
Post by uhi22 »
From my point of view it should work also with a lock motor without feedback. So you could connect the motor leave the feedback unconnected.
The motor should turn as the AcObcState which comes from Zombie demands.
It would help to understand the intended sequence and to compare with the observed behavior.
Something like this, please correct if it is wrong...
1. User plugs in.
2. Foccci sees the PWM and sets isBasicAcCharging.
3. Foccci sets the AcCurrentLimit.
4. Foccci sets the CableCurrentLimit based on the PP resistance.
5. Zombie sees .... and sets AcObcState to Locking.
6. Foccci controls the lock motor (time based) and assumes the locked state is reached.
7. Is Zombie checking the locked state?
8. Zombie is demanding state C by setting AcObcState to CHARGE.
9. Foccci sees AcObcState is CHARGE and turns the CP state C on.
10. EVSE closes the relay.
uhi22
Post by uhi22 »
Plotting the AcObcState could bring some light into the dark.
uhi22 wrote: Wed Feb 05, 2025 9:39 pm From my point of view it should work also with a lock motor without feedback.
This was added (along with now a bunch of other changes) after my work on the Zombie integration and writing the AC charging logic and testing it all with BigPie.
Zombie interaction is based around ChargePortState.
It was working at build 80.
I'm going over the code changes, looking where I changed semantics.
1. I changed CanWatchdog to require ChargeCurrent AND enable to be continuously updated. Before updating one of them was sufficient https://github.com/uhi22/ccs32clara/com ... d7c5bb8638
2. I fixed the lock implementation https://github.com/uhi22/ccs32clara/com ... 8b7ecc8d1c It could happen that the lock motor operated infinitely, among other bugs. This changed the behaviour of LockState
3. PortState changes to PluggedIn when not DC charging and PlugPresent=1. Before it only changed to PluggedIn when CP < 3%. Also changing PortState to Idle when PlugPresent=0. Before it would remain on PluggedIn https://github.com/uhi22/ccs32clara/com ... 847a899f3e
It's probably one of these causing the issues
The AC OBC interface isn't defined outside the source code. So just relying on that no one ever changes the behaviour is a bit volatile as we see.
As uhi has started to line out we should maybe write out the interface on the wiki. Which parameters are involved and what is their value at a given state
manny
Post by manny »
I will get some CAN logs in StandAlone en Cancontrolled mode. probably tomorrow evening.
Then we can compare the states from Foccci and Zombie.
  • Zombie VCU
Had review of the code changes since build 80 could not immediately pinpoint where it would fail.
Need to find time to build my Foccci setup back up for testing with Zombie, but this will be a while since I can get on this.
Zombie sends:
UnlockAllow = UnlockAllow << 7;
    if(ChargeAllow == true)
        bytes[0] = 0x01; //allow starting
        AcOBCReq = 0x08; //Charge AC
    else
        bytes[0] = 0x00; //stop charge
        AcOBCReq = 0x08;
    bytes[0] = bytes[0] | AcOBCReq | UnlockAllow; //
Very basic control, but only really toggles enable, otherwise requests AcOBCReq = 0x02 AC charging (0x08 shift it down 2 as it starts on bit 2).
uhi22
Post by uhi22 »
Let me guess, Focccis Param::LockState is neither locked nor unlocked, and so we are stuck in the state where Zombie demands charging, but Foccci does neither lock (because it is not unlocked) nor it changes to state C (because it is not locked).
https://github.com/uhi22/ccs32clara/blo ... C.cpp#L328
manny wrote: Wed Feb 05, 2025 8:59 pm updated. now on 44.90.b.
manny wrote: Wed Feb 05, 2025 8:59 pm with it set to StandAlone. Foccci enabled the EVSE and after that Zombie enabled the HV.
Nope, as standalone works, which still uses same AC Charge logic, thus requires LockState to work
uhi22
Post by uhi22 »
Just tested on the desk some scenarios. Latest software, #90. Providing CP PWM, no PP connected. AcChargeControl = CANRemoteControlled, but nothing mapped and nothing connected to CAN. No lock feedback connected.
Setting AcObcState in the web interface for testing.
1. IDLE: Blue flashing.
2. LOCK -> motor locks, LED blue solid
3. CHARGING -> green flashing, state C.
4. COMPLETE -> green/blue solid. State B.
5. IDLE -> motor unlocks. blue flashing.
6. directly jump from IDLE to CHARGING -> motor locking, green flashing, state C.
7. button -> motor unlocks, blue flashing, state B.
8. wait 20s -> motor locks, green flashing, state C.
Conclusion: At least this seems to work fine.
params_CI90_AcChargeTestOnDesk.json
parameters for testing ac charging on desk
(613 Bytes) Downloaded 458 times
That is very strange if Enable and AcObcState are mapped it should in theory just work.
@manny probably best to rerun the Zombie "auto config" for Foccci to ensure the CAN map is correct. Then proceed by checking if the params update as expected.
manny
Post by manny »
Started to replicate uhi22 steps but no lockmotor action.
Went to test the lock motor. But have some strange results.
On #90 when using the ActuatorTest motor did nothing. So removed the motor, tested it with a 12 battery it worked fine.
Hooked the scope up to the motor outputs from the Foccci and I see strange behaviour.
With LockClosedThresh and LockOpenThresh set to 0. I get this when switching to CloseLock nothing on Open
With LockClosedThresh set to 0 and LockOpenThresh set to 300. I get this Close both high Open both low
With LockClosedThresh set to 300 and LockOpenThresh set to 0. I get this when switching to Close nothing on Open
Change the firmware to #80 and get expected behaviour.
Open
Close
Next I will get some CAN logs
  • Zombie VCU
manny
Post by manny »
Got two CAN logs, one in standalone and one in cancontrolled.
If I manually change the AcObcState to lock. The spot value also changes to locked
and then to Charging, charging starts.
So it seems that the AcObsState does not get to Focci.
Found it! chaged the CAN mapping for AcObcState, set the lenght to 4 bit. And the AcObcState changed to Charging
standalone_1.csv
(10.78 KiB) Downloaded 464 times
cancontrol_1.csv
(16.76 KiB) Downloaded 471 times
  • Zombie VCU
I will review the code then to update this, I am surprised it worked before then. No idea what done it, maybe the change of the length.
https://github.com/uhi22/ccs32clara/com ... 4e105a0a55
Will review my Foccci code and update. Does you lock work in latest build?
uhi22
Post by uhi22 »
Do we have a dbc for Savvycan which contains the intended signal mapping for the communication between Zombie and Foccci? This would help to have a consistent mapping on both sides and also help to interpret the logs.
Here is one I made earlier. Loads of extra bits as this is just an adjusted DBC.
Indeed obcstate should be 4.
Zombie-Foccci.dbc
(10.02 KiB) Downloaded 445 times
manny
Post by manny »
tom91 wrote: Thu Feb 06, 2025 9:00 pm Does you lock work in latest build?
No, spot value changes as expected, but the physical motor does not move.
Got the new motor today ordered yesterday at 23:45. Delivered today at 19:45. and cheaper than on aliexpress :D
  • Zombie VCU
https://github.com/damienmaguire/Stm32-vcu/pull/157
Update to spec AcObcState to length of 4 in auto map config
uhi22
Post by uhi22 »
manny wrote: Thu Feb 06, 2025 7:00 pm Hooked the scope up to the motor outputs from the Foccci and I see strange behaviour.
The pictures look like one cable of the motor is not connected or not driven. So on both ends of the motor we see the same voltage. If the cable between the motor and Foccci is not the root cause, we need to check what the driver does. It it possible to hook the scope to pin 1 and pin 2 of the driver IC (IC1, DRV8874)? Normally, to drive the motor, one of the pins should be high and the other low. I see no obvious reason in the software, that this control does not work.
When LockOpenThresh and LockClosedThresh are different, then just the timing changes, because the software considers the feedback, instead of using the fix control time LockRunTime. And if the feedback says that the target position is reached, the control stops. So changing the type of motor between "without feedback" and "with feedback" does not help to fix the issue in the control path. We need to find out, why both motor lines go to high when trying to turn the motor.
We could change LockDuty from 100% to lets say 50% to get PWM control of the lock motor, this could help to see on the scope which line is driven in which way.
manny
Post by manny »
The scope shot where taken with the motor disconnected and a channel connected to each of the motor leeds from Foccci.
uhi22 wrote: Fri Feb 07, 2025 7:37 am When LockOpenThresh and LockClosedThresh are different, then just the timing changes, because the software considers the feedback, instead of using the fix control time LockRunTime
A yes this makes sense.
uhi22 wrote: Fri Feb 07, 2025 7:37 am It it possible to hook the scope to pin 1 and pin 2 of the driver IC (IC1, DRV8874)? Normally, to drive the motor, one of the pins should be high and the other low.
Yes will do some tests.
uhi22 wrote: Fri Feb 07, 2025 7:37 am We could change LockDuty from 100% to lets say 50% to get PWM control of the lock motor, this could help to see on the scope which line is driven in which way
Will do
  • Zombie VCU
uhi22
Post by uhi22 »
Oops, found something. 50 is the new 100. I tested yesterday with LockDuty 30%, this worked perfect (always software #90). Just measured the inputs and outputs of the driver, they show PWM, with different duty cycles on both pins, and depending on the lock/unlock direction. Fine, so far, at least if not looking too much into details ;-/
Increasing the LockDuty to 100%, I see the issue: Both lines are controlled to 100% high, no matter of the intended control direction.
Setting LockDuty to 50% seems to be what we wanted with 100%.
So recommendation for the moment: Set LockDuty to something in 30% to 50% range. And we need to understand the PWM ratio calculation and fix this in Foccci.
Edit: The calculation of the pwm based on LockDuty was 50% off.
Fix: https://github.com/uhi22/ccs32clara/com ... c2d3e2d60f
New software #91: https://github.com/uhi22/ccs32clara/act ... 3195982499
