Designing SECC for DC Charging with QCA7000/7005
forecast
Post by forecast »
I want to design Supply Equipment Communication Controller (SECC) without Linux, I want to use cheap microcontrollers (STM32 or another MCUs)
I already started design with STM32 but I don't know how to build software based on QCA7005
Does anyone have any information on this subject or can help?
Re: Designing SECC for DC Charging with QCA7000/7005
I guess you want to look at the Foccci project. It is the EV side, but the hardware is near identical on both sides. Only you need to generate CP PWM, not read it.
Also software will share a lot of code.
When using Foccci knowledge please make your project open source as well
forecast
Post by forecast »
johu wrote: Fri Jan 31, 2025 3:33 pm I guess you want to look at the Foccci project. It is the EV side, but the hardware is near identical on both sides. Only you need to generate CP PWM, not read it.
Thank you for answer.
Yes, I have seen this post before, I already generate CP PWM and I’m considered about software, because I haven’t worked with PLC before.
I will use this project for only communication controller by the way
okiedokie
Post by okiedokie »
forecast wrote: Sat Feb 01, 2025 7:34 pm Thank you for answer.
Hello,
I was also thinking on working on a similar project, maybe we can try to collaborate on this using Foccci as a reference? Feel free to dm me so we can discuss further.
Thanks.
forecast
Post by forecast »
Okay, sounds good.
Please check your message box.
uhi22
Has thanked: 245 times
Been thanked: 684 times
Post by uhi22 »
A starting point (actually perhaps already a solution) for the EVSE side is mentioned here: https://github.com/SmartEVSE/SmartEVSE- ... 2271141043
uhi22
Post by uhi22 »
Cross-linking the flash-images for the QCA7005 in EVSE mode: viewtopic.php?p=33730#p33730
