I've always wanted to convert a vehicle to electric, and this feels like a great candidate. As small as it is, it's mostly empty under the bed. The engine is under the seats, and aft of that the narrow transmission and driveline run down the centre to the rear axle. I did a 3D scan of the underbody and removed the drivetrain and fuel system: The big challenges to the project are two:
Weight - the stock empty weight is 750 kg, plus a 350 kg load capacity.
The rear axle - the available space seems to dictate that a compact drive unit be used, since otherwise my battery space would be cut down the middle.
To give a good idea of the space requirements, here are the general dimensions: Goals:
Must-haves
- Heating and cooling - won’t get driven without it. My last 'fun' car sat idle eight months of the year because of this.
- 55 km of range (a round trip to where we dispose of our household waste)
- No ICE transmission/driveline
- 150 km range (a round trip to The Big City)
- High voltage (400 V, not 48 - 125)
- No visible screens
- No noisy and superfluous vacuum pump
- CCS
