DIY Economiser for OEM Contactors
royhen99
- Has thanked: 22 times
- Been thanked: 133 times
Re: DIY Economiser for OEM Contactors
The problem with the pnp transistor is the base and collector are swapped. In the schematic you have used a spice simulation symbol which has different pin numbers from the transistor used, and states it's for simulation only.
