I'm updating my old F250 EV Conversion using a Leaf motor and Zombieverter.
Are there any display systems that show you things like RPM, Temperature, Amps, Volts, Regen, etc...
I had a nice one I wrote for my old Zilla 2K - but I'm hoping one already exists for a Leaf motor/inverter setup.
Looking for UI/Display to use with Zombieverter
- CasaDelGato
Updating a 17 year old F250 conversion to using a Leaf Motor
- Been thanked: 1913 times
Re: Looking for UI/Display to use with Zombieverter
- J0hannes
- Has thanked: 21 times
- Been thanked: 182 times
I'm not at this point in my project yet that I would have been able to test these in a running vehicle, but I'll share my thoughts what I've had up so far:
The web interface has gauges you can set up to show whatever parameter is used/displayed.
In theory you could use a tablet as your display.
In practice not sure how well that would work as the wireless connection is that stable (at least my experience and similar issues seems to be for other too if you read the forum)
Depending on how much Leaf system you are ending up using, leafspy/pro might be useful (OBD Bt dongle+app)
You might want to check what others are doing in the UI section of the forum too
