Leaf J1772 charger canbus data?
CasaDelGato
Post by CasaDelGato »
Has anyone figured out how to enable the J1772 charger for a Gen2 Leaf system?
I just bought a 110kW unit, and it has the J1772 inlet - with all the wires going to the big box on top of the motor. I'm assuming that the charger must be integrated with the controller.
To get that charger to work is bound to require talking to a BMS so it can figure out what it needs to do.
If I can even find a description of which canbus msgs are needed, I can write the software to deal with it.
Updating a 17 year old F250 conversion to using a Leaf Motor
Been thanked: 1913 times
Re: Leaf J1772 charger canbus data?
This topic is long solved. Search for Zombieverter or Resolve EV
Marat
Been thanked: 12 times
Post by Marat »
The question requires clarification of which PDM is available, in the text 110kw.
Better photo of the block.
CasaDelGato
Thanks for the pointers, I hadn't found Resolve EV yet, nor the Zombieverter.
Looks like the Zombieverter will do what I need.
Note: I have a 2020 Leaf S motor, 110kW.
Marat
Post by Marat »
Engine yes, no PDM yet.
CasaDelGato
Ok, since nobody else has told me how to tell which one, how do I tell which one I have?
