So i am now looking at battery cooling plates for my new conversion from old batteries to NMC. After a lot of research i see many options:
I have been told that driving normally and rarely using rapid charging i would not see a rise in temperature.
It is tempting but in case it does not work the battery case would have to be redone.
2 plates would have a cnc channel in the middle and both plates would be joined, 3 plates could be laser cut and then glued together.
Leaks would have to be carefully tested.
peugeot 208 Extrusions are very interesting, unfortunately it's not easy to find the one you want but custom ones can be made.
I sent multiple emails to businesses around me asking if possible how much would it be to make the following design,
what do you think?
