62kwh Leaf Pack max amps?
ekohn04
Been thanked: 22 times
Post by ekohn04 »
Hey everyone, running a 62kwh leaf pack with my base LDU. Does anyone know how many amps I’ll be able to pull from this pack? Also, does anyone think increasing the busbar size from the ones that come with the pack will help my amps?
Side note, how much can an LDU pull? I know a sport LDU can get up to 1,000 but not sure about base. Thanks guys!
ImportFanatiK
Has thanked: 6 times
Re: 62kwh Leaf Pack max amps?
Post by ImportFanatiK »
Did you ever get an answer to this?
I have a sport LDU and was contemplating the 62kwh leaf pack since it seems like it would be much easier to use than the tesla modules, given that it requires less space to get 400V.
Any regrets?
CrAzY_DrIveR
Has thanked: 13 times
Been thanked: 8 times
Post by CrAzY_DrIveR »
hi, what's the actual busbar size of the 62kwh battery? the 30kwh uses 20x1.6=32mm2
ekohn04
Post by ekohn04 »
Any regrets?
Yes, that's one of the biggest things I would change if I did it all over again. The most I've seen my pack output is 600amps. I'm using Jon Volk's tune for the LDU so I haven't tuned the parameters according to my setup, but that 600amp mark seems to be right in line with my research on the matter. Use Tesla modules, they're water-cooled as well. The Leaf pack will degrade very rapidly from no heat management.
busbar size
I'll need to get back to you on that one.
ekohn04
Post by ekohn04 »
CrAzY_DrIveR wrote: Sat Nov 09, 2024 7:22 pm 20x1.6=32mm2
The busbars of the 62kwh pack are the same size.
