Lilygo T-Can boards for web UI
- Has thanked: 82 times
- Been thanked: 426 times
I'm using a Lilygo T-Can board available from Aliexpress for ~£14 for the can backend web interface. The pin mappings are different and it requires an output setting to enable CAN. Lilygo says max input of 12V but the voltage regulator IC has an absolute max of 18V, it's running fine when my DCDC is active at 14.5V
I'll get round to doing a PR for being able to select the board, but for now the code is here: https://github.com/jamiejones85/esp32-w ... ilygo_tcan
I've implemented a dark mode theme, and also a drive mode page.
Still todo, I want to log all the spot params to the SD card next automatically when driving.
There's a decent 3D printable case for it here: https://github.com/Xinyuan-LilyGO/T-CAN485/pull/26
- Has thanked: 220 times
- Been thanked: 178 times
Re: Lilygo T-Can boards for web UI
That looks great!
One thing to consider for dark mode, blue is the least friendly color for eye strain. It can also mess with circadian rhythm (can mess with your sleep cycle after dusk.)
I know, lots of dark modes use blue as their main color after black / dark. I'm guessing they aren't aware of these 2 things when choosing or using blue.
It's fairly easy to change colour scheme so might add some more and a switcher at some point.
I am struggling to compile the esp32-web-interface-lilygo_tcan. Arduino IDE detects the board as a lilygo T-display but there is no board listed as the lilygo T-can. I have now got all the needed libraries but I am getting this error,
In file included from C:\Users\Administrator\Documents\Arduino\libraries\SD\src/utility/Sd2Card.h:26,
from C:\Users\Administrator\Documents\Arduino\libraries\SD\src/utility/SdFat.h:29,
from C:\Users\Administrator\Documents\Arduino\libraries\SD\src/SD.h:20,
from C:\Users\Administrator\Desktop\esp32-web-interface-lilygo_tcan\esp32-web-interface\esp32-web-interface.ino:57:
C:\Users\Administrator\Documents\Arduino\libraries\SD\src/utility/Sd2PinMap.h:527:2: error: #error Architecture or board not supported.
527 | #error Architecture or board not supported.
Any help would be appreciated
Are you using Arduino IDE or platform IO?
Are you using the branch on my repo or the Johannes repo?
I am using Arduino IDE 1.8.19. The attached is a picture of the suggested settings for the tcan from lilygo for programming the board also the board I have selected is ESP32 dev Module. The repo is from Jamies github.
When I try to compile i get this output,
Thanks for looking at this Bigpie.
I've attached the compiled binaries, you can use something like https://github.com/doayee/esptool-esp32 ... es/tag/0.1 to flash them.
- spiffs.bin
- (1.44 MiB) Downloaded 545 times
- firmware.bin
- (899.34 KiB) Downloaded 567 times
Thanks bigpie. BUT, sorry to be a pain i have 3 options boxes, Flash app, flash partition and flash boot loader. I flashed both bins to flash app and had a firmware update page when connecting to the board wifi with 192.168.4.1 but thats all i got . I think I may need to erase and start again but the programme says I must flash all 3 files and I only have to.
As you can guess I am a bit of a numpty in this field
firmware.bin goes to app, spiffs to partition, bootloader doesn't need changing. I don't use windows, so not familiar with apps on it.
little steps, I tried stm32-vcu.bin in update firmware it says update errorwrong magic byte
If you're getting can communications, and you want to update the STM32 you need to use the update on the main interface page.
Sorry to waste all your time.
Yep, I tried the stm vcu.bin out of desperation. I can now connect to the board again but when I do "file not found" comes up then I get the upload page.
I have managed to get the firmware.bin to upload but the filesystem spiffs.bin gives an Update error "Bad size Given"
- Has thanked: 41 times
- Been thanked: 10 times
In first place I did try wrong branch, after getting correct one it gives me some errors about setValueSdo() function, commented errror lines to get lilygo-tcan compile somehow.
I have not used esptool.py before to flash whole thing, so I compiled using Arduino 2.3.3 and same board settings as dadiowe above, I also can go to 192.168.4.1/update and try upload filesystem using spiffs.bin complains the same "Bad size given". I can update attached firmware.bin using /update page, but no difference using it.
Tried using upload.sh 192.168.4.1, it does not complain anything but still no pages other than /update and some "buildin" pages like /sdcard/list and /version which do respond.
Trying using browser 192.168.4.1/edit which upload.sh uses, gives FileNotFound output. So something to do with spiffs?
Changed Partition Scheme to "No OTA (2MB APP/2MB SPIFFS)" with no difference. Like "Erase All Flash Before Sketch Upload: Enabled" to erase everything.
Something is wrong but I don't understand what..
are you using Windows? I've some fresh boards coming and will do some step by step instructions for boards out of the box. I don't use windows usually but got an old windows laptop that I'll use for it.
The bad size given might be a library version issue https://github.com/espressif/arduino-esp32/issues/6482
These are the exact versions I have
Dependency Graph
|-- ESP32Time @ 2.0.6
|-- ArduinoJson @ 6.21.5
|-- StreamUtils @ 1.9.0
|-- SPI @ 2.0.0
|-- ArduinoOTA @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- FS @ 2.0.0
|-- HTTPUpdateServer @ 2.0.0
|-- SD @ 2.0.0
|-- Ticker @ 2.0.0
|-- WebServer @ 2.0.0
|-- WiFi @ 2.0.0
|-- SPIFFS @ 2.0.0
|-- EEPROM @ 2.0.0
This is really cool! The second screenshot with the battery info, how is it getting that to the web interface?
It's getting the values from zombie. So depends on components used, but BMS/Shunt integration populates the spot values and the UI grabs them for display
I only use Linux, esptool would be nice but I did not get it to work yet, even Arduino uses it for uploading.Bigpie wrote: ↑Wed Oct 16, 2024 6:53 pm are you using Windows? I've some fresh boards coming and will do some step by step instructions for boards out of the box.
esptool.py -p /dev/ttyACM0 write_flash 0x10000 firmware.bin -e
After this wifi never comes available.
Edit: after one arduino flash I could flash firmware with esptool without flash erase; it was missing bootloader I believe. Still don't know what address spiffs should be written.
Upgraded Arduino ESP32 libraries from 3.0.0 to 3.0.5 with no change.
Because I did not get esptool flash with correct firmware.bin to boot, my plan was to compile and use /update to update firmware.bin. This succeeded, but was not happy if I uploaded Filesystem spiffs.bin, same error. Maybe web firmware update did not succeeded after all, not sure.
So, just had a couple of box fresh Lilygos delivered to do this.
Here's the esptool command, all binaries in the attached zip.
I'll next switch to windows and find a GUI tool for the other.
esptool.py --chip esp32 --port "/dev/cu.wchusbserial58CE0145831" --baud 460800 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 40m --flash_size 4MB 0x1000 bootloader_qout_40m.bin 0x8000 partitions.bin 0xe000 boot_app0.bin 0x10000 firmware.bin 0x00290000 spiffs.bin
- lilygo-ui.zip
- (867.86 KiB) Downloaded 491 times
- Has thanked: 5 times
- Been thanked: 5 times
On a slight tangent, you can do firmware downloads via USB using Chromium/Chrome/Edge browser.
An example is the firmware for Meshtastic LoRa networks...
https://flasher.meshtastic.org/
Many thanks, this has been great solution to add wifi range! Will try with external antenna some day to get even better.
When using mostly with zombie I can't see all spot values, just for example I12 and current time values. What makes values to be shown?
Also I think I saw current CAN mappings in the beginning but now shows nothing. Tried to add one mapping which did not show up in UI, so I verified with OIC tool and all mappings including new one was there. ESP32 reset or power cycle not bringing CAN mappings to UI. Any ideas?
This must have been bus related problem, now that I removed lilygo CAN termination (three termination on the bus), all spot values and CAN mappings are shown.evMacGyver wrote: ↑Fri Nov 08, 2024 6:16 am When using mostly with zombie I can't see all spot values, just for example I12 and current time values. What makes values to be shown?
New problem, sometimes webui stops answering. Ping is always ok, even curl can't get any answer, not even /wifi or some static page. I might try another lilygo if its just faulty board.
- Has thanked: 13 times
Spent a while getting to this stage but have something loaded and can connect to the web server......but all I get is the update page as above....I used a fresh install of platformio (that already has Arduino 2.x and 1.8) on a windows laptop and the platformio.ini.
There was an RTC lib issue it appears that the library has been condensed but finally got it compiled and loaded but no Bueno.....
As I have a similar issue as above I was wondering if anyone has a direction of travel that might help with this.....thanks in advance
Not my picture but getting same
- 173417478876747142781032925633.jpg (28.16 KiB) Viewed 7822 times
easiest way is to use the command line I provided above to flash the binaries.
From your /update you can use the precompile spiffs.bin from the lilygo-ui.zip above and upload that to the file system. The firmware.bin is also in there you can flash the firmware too.
So I got it to work! Using esptool. The syntax took some adjustments for windows. And was a bit of a learning curve.
First install python and pip (was prompted if I wanted to install pip at the time of installation) from python.org
So to install esptool that is done from a windows command prompt. NOT in python. (Followed this video(
pip install esptool
Then after downloading the zip files (can't remember where I put them at the moment will post back) and working out which port I was connected to......windows version of esptool syntax used COM port.
Then adapted your command line and bam.....it worked.
Took a pic at the time..... shown below......will try and supply a more in depth instructions.
Thanks Jamie!
pip install esptool
Thanks Jamie!
