Two FOCCCI's on the same bus
- uhi22
- Has thanked: 205 times
- Been thanked: 611 times
Re: Two FOCCCI's on the same bus
We have a confusion regarding the Clara version. On the github continuous integration page (on the "actions" tab) https://github.com/uhi22/ccs32clara/actions, there are the binaries available for each official version. The latest version is on the top of the list, with the highest run number. In this case, the #72 contains the fix:
In the "Artifacts" section of this run there are the zipped bin and hex files for flashing. After flashing, e.g. with STlink command line utility
ST-LINK_CLI -P stm32_canloader.hex -P CI_72.hex -V
the serial log of Clara should show the version:
This is Clara version 4=0.42.72.B
githubRunNumber 72
The 72 in the version and the githubRunNumber 72 are referring to the continuous integration build 72.
githubRunNumber 72
<Update 10/18/2024>
I updated the Clara firmware to version 4=0.42.73.B.
Then, I have had success using two chargers at the same time.
But it's not stable: sometimes it works, sometimes it doesn't.
I am attaching the log of when the double charge was successful. Also, after the firmware update I am losing communication using the ESP32 CAN Web Interface.
I would like you to look at this data and make improvements to ensure stable charging.
- Has thanked: 215 times
- Been thanked: 174 times
If you're asking people to do things you should offer them a bounty / support them. If you are already, great.
- Has thanked: 369 times
- Been thanked: 1544 times
- uhi22
On first reading, I misread as
"I would like to look at this data and make improvements to ensure stable charging."
and thought "great, we have a new contributor".
The log of the good case does not help to understand the bad case. We need the log of the bad case for analysis.
- uhi22
Summary of this log:
- It contains a failed part (see below) and a successful part afterwards.
- The intended bugfix, that we ignore foreign slac_match confirmations, works as intended:
[294300] [PEVSLAC] received SLAC_MATCH.CNF but with foreign destination MAC. Ignoring.
[297840] [TCP] Last packet wasn't ACKed for 100 ms, retransmitting
- Later in the cable check, the TCP connection is lost completely after 10 retries, due to lost packages:
[301260] [TCP] Last packet wasn't ACKed for 100 ms, retransmitting
[301370] [TCP] Giving up the retry
[333920] Safe-shutdown-sequence: setting state B
- Session is stopped on charger side [599400] Checkpoint790: Charging is terminated from charger side.
- uhi22
More interesting details: After the TCP gave up during CableCheck
the charger later sends again data
and the ping pong continues
And after Foccci sent again a CableCheck request, we get from the charger
and ignore these messages completely.
So two things to be done:
* The TCP timeout could be a bit longer than the currently implemented 10*100ms, because obviously sometimes the charger needs longer (~2s in this log).
* Analyze what messages does the charger send as last two, and why Foccci does not react on them.
[300180] [TCP] Last packet wasn't ACKed for 100 ms, retransmitting
[302160] ETH rx IP:
[302160] ETH rx IP:
[302160] [TCP] sending ACK
[304190] ETH rx IP: 023304732057a0b0c0d2345b86dd6000000000140640fe80000000000000a2b0c0fffed2345bfe80000000000000c69083f3fbcb981ec350e754362bf283000001b45010038464f90000
[304280] ETH rx IP: 023304732057a0b0c0d2345b86dd6000000000140640fe80000000000000a2b0c0fffed2345bfe80000000000000c69083f3fbcb981ec350e754362bf283000001b45014038464f50000
- uhi22
Clarified: The last two messages from the charger are just a TCP ack and reset:
So let's increase the TCP timeout and see how this improves the situation. Issue created: https://github.com/uhi22/ccs32clara/issues/43
[Edit] Done: https://github.com/uhi22/ccs32clara/com ... 21ef3d3ec4
This indicates that the charger does not want to further talk on this TCP connection (socket was closed).So let's increase the TCP timeout and see how this improves the situation. Issue created: https://github.com/uhi22/ccs32clara/issues/43
