ESP32 Based Web Interface & Data Logger
- Has thanked: 2 times
- Been thanked: 11 times
Re: ESP32 Based Web Interface & Data Logger
With platormio i did an upload but then i couldn't connect to the wifi anymore.
I updated the firmware via the arduino ui, then with platformio i did a uploadfs.
here is what i get when i change the node ID or the can speed. with arduino ui (1.8.19) i can't use the esp8266 upload data as it says it's incompatible with esp32.
I was able to compile/upload the arduino sketch when i selected nano32 as target.
EDIT : got the ESP32 sketch data uploader and used it, but still the same error when chaning the can speed or node id.
EDIT2 : It now works, I hooked up my candapter and it now worked. I guess it needed the candapter to do the ack of the messages.
as i don't have anything else connected on the bus yet.
- Has thanked: 369 times
- Been thanked: 1543 times
seems more like it used a cached ui.js
2 participants is enough because both ESP and STM will ACK
- Has thanked: 82 times
- Been thanked: 422 times
I've been using the ESP32 based web interface, over can for last day or 2. It keeps getting into a state where the ESP32 cannot communicate with the Zombie MCU.
I've added a button to the UI to restart the ESP32 and communication resumes. I'm thinking maybe it's triggering the ESP32 can buffer overflow bug?
- uhi22
- Has thanked: 204 times
- Been thanked: 611 times
Maybe add another button which just re-initializes the CAN controller, to confirm or refuse the assumption. And add two counters for debugging, one for "CAN transmit attempt" and one for "received a message from CAN", and show them in the web interface. To get an idea where it is stuck.
Edit: There seems to be error counters which we could also show. Mentioned here https://www.esp32.com/viewtopic.php?t=5010
Edit2: The link points also to an example code which contains
CAN_bus_off_recovery()
During a recent debug session we found that the invalid json check triggered after 5 minutes. This is odd as it should just load the same json as before but instead it detects an error and deletes the json file. Apparently the re-download doesn't work until you restart or change the node id to something else and back.
I think it is worthwhile commenting it out https://github.com/jsphuebner/esp32-web ... n.cpp#L340
I've just commented out like this
if (result != DeserializationError::Ok) {
// SPIFFS.remove(jsonFileName); //if json file is invalid, remove it and trigger re-download
// updstate == REQUEST_JSON;
// retries = 50;
// DBG_OUTPUT_PORT.println("JSON file invalid, re-downloading");
return false;
Seems to no longer have the issue, I've not noticed any strange behaviour so far.
// retries = 50;
return false;
Just got a new thing while remaking my can man
Edit : I've commented the lines, reuploaded the code to the ESP the wired way, but still no luck. same behaviour, i can't add can messages to the can map. I'm very lost on the workings of this, any help ?
i haven't done the comments to remove the json issue, could this be linked ?Edit : I've commented the lines, reuploaded the code to the ESP the wired way, but still no luck. same behaviour, i can't add can messages to the can map. I'm very lost on the workings of this, any help ?
- Has thanked: 69 times
- Been thanked: 88 times
If you look closely you can see the problem: The line that updates the "updstate" should be "updstate = REQUEST_JSON" rather than doing an == comparison and then discarding the result.Bigpie wrote: ↑Fri Jun 28, 2024 9:23 am I've just commented out like this
// retries = 50;
return false;
I turned on -Wall to try and fix the Arduino IDE build which was breaking for me and it highlighted this amongst a bundle of other less serious problems. I'm putting together a PR.
Cross posting here: a problem with recovering from a failed firmware update hast been fixed: viewtopic.php?t=5223
https://github.com/jsphuebner/esp32-web ... ace/pull/9 I've done a PR for configurable can pins.
Not sure where to ask this, maybe here makes sense. I've flashed my esp32 per the instructions on the github but the web interface seems a bit flaky. 'settings' and 'wifi settings' are both blank when I click them (except one time it showed up after waiting 5 minutes or so). Is that normal or does it indicate something went wrong? The same interface on my Wemos D1 seems pretty fast and smooth by comparison. Should I try re-uploading the SPIFFS?
Also, trying to enter a node/speed doesn't seem to work and I can't get parameters or spot values from my Foccci (though it's freshly flashed, I cant be certain it's working right either, but I am thinking since the web UI is acting strange I should start there).
- uhi22
This sounds like an instable ESP32. My first point to check would be to have a strong 5V power supply for it. Had bad experiences using crappy USB cables. The ESP needs some current for wifi, and tends to crash if the power drops.
Ah, interesting. I'm using a 12v benchtop power supply though, so I don't think it would be that.
Does this all seem correct? Wondering if maybe one of 'events' or 'arduino' should be on core 0? These are all what came up by default. (Edit: actually from another forum it looks like that would be a bad idea, apparently it runs the wifi stuff on core 0.)
- uhi22
Is it possible to view the ESPs serial? It should give hints how far it comes and what is the reason for crashing.
Well I had the monitor running but didn't get anything out of it after the initial bootup. I even tried a full wipe of the ESP and re-flashed it via the arduino IDE (and the web interface CAN-Backend fork which I just downloaded as a zip and extracted to my workspace). Basically I've discovered it will load all the pages except Settings and Wifi Settings on the first try. And if i refresh the page then click settings, it's about 50-50 whether it will load or give me a blank screen. And of course no parameters or spot values are coming through from Foccci when I enter node 22/500k.
Not sure if this tells us anything useful or not.
- uhi22
I'm using an older version (not really sure, something from December 2023 I assume), but can confirm, that the error with the missing subscription.js is also present here. If I try to open http://inverter.local/subscription.js I get a HTTP 404 (file not found). So this seems to be "normal".
When just opening the main page, I get some errors, but they seem not to block the functionality: No idea what could be the issue on your side. Maybe try an other version, and different browsers. I'm using Chrome and Edge, no problems here with the "December 2023?" version.
Ah, good idea, thank you.
So I tried the commits from December and can't get any on the can fork to compile. I assume it's an issue with one of the libraries since I can't find the offending line anywhere in the repository, but I'm not sure how to figure out what library it is.
The good news is that I was able to flash something from the UART fork from that time period, and with the older UI everything was nice and smooth. No ability to check CAN obviously, but, progress! Next step will be to start rolling back the libraries I can find and see what happens.
edit: Actually my search wasn't picking it up and after looking through the verbose output it's something to do with oi_can.cpp. Trying newer versions to see if it will compile or if I can figure out how to fix it.
Aha, it's referenced in the July 14 commit, which might be too recent but apparently it has to do with the compiler:
Unfortunately that version has the new UI so back to square 1 unless I can figure out how to roll back the compiler.
Compilation error: call of overloaded 'setValueSdo(int, int, unsigned int)' is ambiguous
318 | setValueSdo(SDO_INDEX_COMMANDS, SDO_CMD_RESET, 1U);
* Fix ambigous overload of OICan::setValueSdo()
The newer gcc 12.2 compiler in the Arduino platform for the ESP32
objects to the overload of OICan::setValueSdo(). As the floating
point conversion is used in only one place it is probably
easiest to move the conversion to the call site.
subscription.js only exists if you subscribed to a parameter set which I think hardly anyone does. So it's "normal" that it doesn't exist.
Progress!(?)
Went back the latest everything. Not able to get settings or wifi settings to show anything even when I reload now, but I did enter the node id, left it alone for a bit and I still have nothing in parameters or spot values, but it DOES have a json that appears valid when checked online. I hope that's a good thing?
So far same behavior in chrome, firefox and edge
"UdcDivider": {"unit":"dig/V","id":1,"value":10.00,"isparam":true,"minimum":0.00,"maximum":100.00,"default":10.00,"category":"Hardware Config","i":0},
"EconomizerDuty": {"unit":"%","id":7,"value":100.00,"isparam":true,"minimum":0.00,"maximum":100.00,"default":100.00,"category":"Hardware Config","i":1},
"InletVtgSrc": {"unit":"0=ChargerOutput, 1=AnalogInput, 2=CAN","id":8,"value":0.00,"isparam":true,"minimum":0.00,"maximum":2.00,"default":0.00,"category":"Hardware Config","i":2},
"LockDuty": {"unit":"%","id":14,"value":30.00,"isparam":true,"minimum":-100.00,"maximum":100.00,"default":30.00,"category":"Hardware Config","i":3},
"LockRunTime": {"unit":"ms","id":13,"value":1500.00,"isparam":true,"minimum":0.00,"maximum":10000.00,"default":1500.00,"category":"Hardware Config","i":4},
"LockClosedThresh": {"unit":"dig","id":11,"value":0.00,"isparam":true,"minimum":0.00,"maximum":4095.00,"default":0.00,"category":"Hardware Config","i":5},
"LockOpenThresh": {"unit":"dig","id":12,"value":0.00,"isparam":true,"minimum":0.00,"maximum":4095.00,"default":0.00,"category":"Hardware Config","i":6},
"TempSensorNomRes": {"unit":"Ohm","id":26,"value":10000.00,"isparam":true,"minimum":1.00,"maximum":1000000.00,"default":10000.00,"category":"Hardware Config","i":7},
"TempSensorBeta": {"unit":"","id":27,"value":3900.00,"isparam":true,"minimum":1.00,"maximum":100000.00,"default":3900.00,"category":"Hardware Config","i":8},
"ppvariant": {"unit":"","id":28,"value":0.00,"isparam":true,"minimum":0.00,"maximum":9.00,"default":0.00,"category":"Hardware Config","i":9},
"WakeupPinFunc": {"unit":"0=Level, 1=Pulse, 2=LevelOnValidCp, 3=PulseOnValidCp, 4=LevelOnValidPP","id":30,"value":0.00,"isparam":true,"minimum":0.00,"maximum":4.00,"default":0.00,"category":"Hardware Config","i":10},
"NodeId": {"unit":"","id":21,"value":22.00,"isparam":true,"minimum":1.00,"maximum":63.00,"default":22.00,"category":"Communication","i":11},
"CanSpeed": {"unit":"0=125k, 1=250k, 2=500k, 3=800k, 4=1M","id":22,"value":2.00,"isparam":true,"minimum":0.00,"maximum":4.00,"default":2.00,"category":"Communication","i":12},
"MaxPower": {"unit":"kW","id":17,"value":100.00,"isparam":true,"minimum":0.00,"maximum":1000.00,"default":100.00,"category":"Charge parameters","i":13},
"MaxVoltage": {"unit":"V","id":18,"value":410.00,"isparam":true,"minimum":0.00,"maximum":1000.00,"default":410.00,"category":"Charge parameters","i":14},
"MaxCurrent": {"unit":"A","id":19,"value":125.00,"isparam":true,"minimum":0.00,"maximum":500.00,"default":125.00,"category":"Charge parameters","i":15},
"TargetVoltage": {"unit":"V","id":3,"value":0.00,"isparam":true,"minimum":0.00,"maximum":1000.00,"default":0.00,"category":"Charge parameters","i":16},
"ChargeCurrent": {"unit":"A","id":4,"value":0.00,"isparam":true,"minimum":0.00,"maximum":500.00,"default":0.00,"category":"Charge parameters","i":17},
"soc": {"unit":"%","id":5,"value":0.00,"isparam":true,"minimum":0.00,"maximum":100.00,"default":0.00,"category":"Charge parameters","i":18},
"BatteryVoltage": {"unit":"V","id":6,"value":0.00,"isparam":true,"minimum":0.00,"maximum":1000.00,"default":0.00,"category":"Charge parameters","i":19},
"enable": {"unit":"0=Off, 1=On","id":23,"value":1.00,"isparam":true,"minimum":0.00,"maximum":1.00,"default":1.00,"category":"Charge parameters","i":20},
"AcObcState": {"unit":"","id":29,"value":0.00,"isparam":true,"minimum":0.00,"maximum":15.00,"default":0.00,"category":"Charge parameters","i":21},
"DemoVoltage": {"unit":"V","id":20,"value":0.00,"isparam":true,"minimum":0.00,"maximum":500.00,"default":0.00,"category":"Testing","i":22},
"DemoControl": {"unit":"0=CAN, 234=StandAlone","id":25,"value":0.00,"isparam":true,"minimum":0.00,"maximum":511.00,"default":0.00,"category":"Testing","i":23},
"ActuatorTest": {"unit":"0=None, 1=OpenLock, 2=CloseLock, 3=Contactor, 4=LedRed, 5=LedGreen, 6=LedBlue, 7=StateC","id":9,"value":0.00,"isparam":true,"minimum":0.00,"maximum":7.00,"default":0.00,"category":"Testing","i":24},
"logging": {"unit":"0=None, 1=ConnMgr, 2=HwInterface, 4=Homeplug, 8=StateMachine, 16=QCA, 32=Tcp, 64=TcpTraffic, 128=IPV6, 256=ModemFinder, 512=SDP, 1024=EthTraffic, 2047=All, 959=AllButTraffic","id":15,"value":1645.00,"isparam":true,"minimum":0.00,"maximum":2047.00,"default":1645.00,"category":"Testing","i":25},
"opmode": {"unit":"0=Off, 1=Connecting, 2=Connected, 3=NegotiateProtocol, 4=SessionSetup, 5=ServiceDiscovery, 6=PaymentSelection, 7=ContractAuthentication, 8=ChargeParameterDiscovery, 9=ConnectorLock, 10=CableCheck, 11=PreCharge, 12=ContactorsClosed, 13=PowerDelivery, 14=CurrentDemand, 15=WaitCurrentDown, 16=WeldingDetection, 17=SessionStop, 18=Error, 19=Timeout, 20=WaitForChargerShutdown, 21=WaitForContactorsOpen, 22=End,","id":2000,"value":0.00,"isparam":false},
"version": {"unit":"4=0.38.B","id":2001,"value":4.00,"isparam":false},
"githubRunNumber": {"unit":"","id":2026,"value":14.00,"isparam":false},
"lasterr": {"unit":"0=NONE, 1=CANTIMEOUT, 2=PLCTIMEOUT, 3=PRECTIMEOUT, 4=LOCKTIMEOUT, 5=EVSEFAULT, 6=RELAYWELDED,","id":2002,"value":1.00,"isparam":false},
"EvseVoltage": {"unit":"V","id":2006,"value":0.00,"isparam":false},
"EvseCurrent": {"unit":"A","id":2010,"value":0.00,"isparam":false},
"InletVoltage": {"unit":"V","id":2007,"value":0.00,"isparam":false},
"EvseMaxCurrent": {"unit":"A","id":2008,"value":0.00,"isparam":false},
"EvseMaxVoltage": {"unit":"V","id":2009,"value":0.00,"isparam":false},
"ControlPilotDuty": {"unit":"%","id":2012,"value":0.00,"isparam":false},
"temp1": {"unit":"°C","id":2003,"value":-45.87,"isparam":false},
"temp2": {"unit":"°C","id":2004,"value":-52.18,"isparam":false},
"temp3": {"unit":"°C","id":2005,"value":-51.87,"isparam":false},
"MaxTemp": {"unit":"°C","id":2024,"value":-45.87,"isparam":false},
"ContactorDuty": {"unit":"%","id":2013,"value":0.00,"isparam":false},
"AdcLockFeedback": {"unit":"dig","id":2011,"value":4033.00,"isparam":false},
"AdcProximityPilot": {"unit":"dig","id":2018,"value":3023.00,"isparam":false},
"ResistanceProxPilot": {"unit":"ohm","id":2019,"value":2819.93,"isparam":false},
"CableCurrentLimit": {"unit":"A","id":2020,"value":0.00,"isparam":false},
"EvseAcCurrentLimit": {"unit":"A","id":2021,"value":0.00,"isparam":false},
"AdcHwVariant": {"unit":"","id":2022,"value":1137.00,"isparam":false},
"HardwareVariant": {"unit":"","id":2025,"value":4005.00,"isparam":false},
"AdcIpropi": {"unit":"","id":2023,"value":73.00,"isparam":false},
"LockState": {"unit":"0=None, 1=Open, 2=Closed, 3=Opening, 4=Closing","id":2014,"value":0.00,"isparam":false},
"StopReason": {"unit":"0=None, 1=Button, 2=MissingEnable, 3=CANTimeout, 4=ChargerShutdown, 5=AccuFull, 6=ChargerEmergency","id":2017,"value":0.00,"isparam":false},
"checkpoint": {"unit":"dig","id":2015,"value":6.00,"isparam":false},
"CanWatchdog": {"unit":"dig","id":2016,"value":30.00,"isparam":false},
"cpuload": {"unit":"%","id":2094,"value":0.28,"isparam":false},
"serial": {"unit":"","value":"57197004","isparam":false}
Got an old version working! I had to roll back the esp32 version in the board manager to 2.0.17 in the Arduino IDE to avoid the compile error (but not until after flashing the OTA sketch to upload the spiffs). Seems like all is good with this version, so I'm happy with that. Appreciate the help guys.
If anyone else experiences something similar, this is the commit that I used: https://github.com/jsphuebner/esp32-web ... e87c7acc8d
And don't forget to fully wipe the board before changing versions. I used a command in powershell to accomplish that.
Edit: Also, I just did a github pull request on the hardware, noticed the tx/rx pin labels were reversed on the silkscreen. That's my very first time doing something like that so hopefully it works...
python -m esptool --chip esp32 erase_flash
I just found a bug today after losing my mind about the connection problems. Had always the message „can’t establish connection between esp an stm „ the one in red. When I just hint in settings the button to apply changes of the can pins even without changing the pin it works like a charm.
Without having reviewed the code I would suggest to have baking of watchdog being triggered by the connection error that triggers the apply changes (properly some connection reset).
Just saw this. Can you add it as an issue to https://github.com/jsphuebner/esp32-web-interface/ and maybe flag @jamiejones85 ?
I have worked on various firmwares.
- Added userspace SDO processing to libopeninv
- Added standard SDO commands as separate module to libopeninv
- Added Custom "start" and "stop" SDO command to stm32-sine, compatible with the existing implementation in oic
- Added start and stop support to esp32-web-interface
If you've always been missing this functionality you can upgrade your esp32 module and also flash the latest stm32_*.bin from https://github.com/jsphuebner/stm32-sine/actions
I fixed a bug in the ESP firmware that I discovered with inverter firmware 5.27.R (or rather the associated libopeninv version). This firmware seems to have issues sending out the CAN mapping and it never sends the termination message. Consequently the ESP is stuck in an endless loop and at some point stops responding.
I've fixed this by limiting the SDO sub index to 100 (about 30 mapping in one message).
https://github.com/jsphuebner/esp32-web ... 0d52b2d6ae
- Proton
- Has thanked: 179 times
- Been thanked: 41 times
I was getting ready to ask you about that. As soon as I turn the ignition on the Esp stops the connection the the inverter and BMS modules.johu wrote: ↑Tue Mar 25, 2025 9:34 am I fixed a bug in the ESP firmware that I discovered with inverter firmware 5.27.R (or rather the associated libopeninv version). This firmware seems to have issues sending out the CAN mapping and it never sends the termination message. Consequently the ESP is stuck in an endless loop and at some point stops responding.
That would be a different issue. The bugfix above only applies to the first page load when it asks for the CAN mappings
