Simp BMS
kn1g
Re: Simp BMS
Post by kn1g »
I have the Tesla B-Class BMB (7s) with a SIMP BMS and I tried to test them the first time. I checked one BMB connected to three Nissan Leaf Gen 2 Packs (each pack is 2S 2P).
Temp test worked. Voltage somehow worked except for the last two reads. It splits my one BMB into two and shows wrong values for the "second" module.
I am an absolute beginner. I read as much as I can (manual, Forum, etc.) but obviously missed the puzzle piece what I messed up here.
I might have missed something obvious. The BMS shows the following:
BMS Status : 1 Ready   |Balancing Active  6
Out:0000 Cont:0000 In:0000 Charge Current Limit : 16 A DisCharge Current Limit : 0 A
Modules: 2 Cells: 6 Strings: 1  Voltage: 22.220V   Avg Cell Voltage: 3.652V  Low Cell Voltage: 3.091V   High Cell Voltage: 4.012V Delta Voltage: 921mV   Avg Temp: 27.747C
Module #1   15.01V   Cell0: 3.74V   Cell1: 3.74V   Cell2: 3.77V   Cell3: 3.77V   Cell4: 0.00V   Cell5: 0.00V  Neg Term Temp: 21.92C  Pos Term Temp: 33.52C
Module #2   7.21V   Cell6: 4.01V   Cell7: 3.09V   Cell8: 0.00V   Cell9: 0.10V  Cell10: 0.00V  Cell11: 0.00V  Neg Term Temp: 21.86C  Pos Term Temp: 33.68C
CANbus   0.00mA  9% SOC 6000.00mAh
The BMS config is set to:
0 – slaves in parallel = 1
a – cells in series = 6
Why does it split the modules with incorrect reads? (I attached an image how I the pins are connected)
Has thanked: 207 times
Been thanked: 563 times
Re: Simp BMS
It splits it because of the way the BMB works it contains 2x bms slave ICs that can measure 6 cells each.
Split 4 - 3. You only wired up 6 cells to a 7 Cell BMB so the second part is upset.
kn1g
Re: Simp BMS
Post by kn1g »
Ok thanks! 8-) I used 6 Packs (making it 14 cells) and attached two BMBs. Everything seems to work fine. I have 14 "modules" with 4 - 3 voltage readings that are all correct.
However, this means that I cannot run the BMBs if the number of cells/packs I want to monitor is not x%7=0? The BMB will always be "upset" and I cannot trick it such that I might have some voltage sens unused (e.g. as in my small rc-plane battery charger)?
What's the best way to debug why one temp sensor shows -83 degrees? I checked the sensors resistance and they seem to be fine. I swapped them and they work on the other pins.
BMS Status : 1 Ready     14
Out:0000 Cont:0000 In:0000 Charge Current Limit : 0 A DisCharge Current Limit : 30 A
Modules: 4 Cells: 14 Strings: 1  Voltage: 52.734V   Avg Cell Voltage: 3.766V  Low Cell Voltage: 3.738V   High Cell Voltage: 3.792V Delta Voltage: 54mV   Avg Temp: 13.553C
Module #1   15.01V   Cell0: 3.74V   Cell1: 3.74V   Cell2: 3.76V   Cell3: 3.76V   Cell4: 0.00V   Cell5: 0.00V  Neg Term Temp: 23.23C  Pos Term Temp: 34.33C
Module #2   11.29V   Cell6: 3.76V   Cell7: 3.76V   Cell8: 3.77V   Cell9: 0.00V  Cell10: 0.00V  Cell11: 0.00V  Neg Term Temp: 23.49C  Pos Term Temp: 34.29C
Module #3   15.10V  Cell12: 3.79V  Cell13: 3.76V  Cell14: 3.77V  Cell15: 3.77V  Cell16: 0.00V  Cell17: 0.00V  Neg Term Temp: -83.08C  Pos Term Temp: 15.67C
Module #4   11.34V  Cell18: 3.77V  Cell19: 3.78V  Cell20: 3.78V  Cell21: 0.00V  Cell22: 0.00V  Cell23: 0.00V  Neg Term Temp: 25.04C  Pos Term Temp: 35.45C
CANbus   0.00mA  61% SOC 36600.00mAh
Re: Simp BMS
kn1g wrote: Mon Jun 24, 2024 10:35 am However, this means that I cannot run the BMBs if the number of cells/packs I want to monitor is not x%7=0?
Tie the highest cells togehtor and check, so for 6 do 6+7 to cell 6.
kn1g wrote: Mon Jun 24, 2024 10:35 am What's the best way to debug why one temp sensor shows -83 degrees? I checked the sensors resistance and they seem to be fine. I swapped them and they work on the other pins.
If you swap BMBs does the issue move with the BMB or stay with the connector? It sounds like a connection issue or BMB solder joint issue (quiet common)
kn1g
Re: Simp BMS
Post by kn1g »
tom91 wrote: Mon Jun 24, 2024 11:07 am If you swap BMBs does the issue move with the BMB or stay with the connector? It sounds like a connection issue or BMB solder joint issue (quiet common)
It seems to be the BMB. I switched them and it switches the incorrect temp reading. Ok, something related to the BMB like solder joint issue would have been the last I'd have expected :roll: thx!
alexbeatle
Has thanked: 71 times
Been thanked: 28 times
Re: Simp BMS
Post by alexbeatle »
To confirm on the simpbms with Tesla SDU OI board.
If SDU params are Idc max=150A(consume) and Idc min = -500A(Regen), that means the simpbms discharge should be set to 150A and the charge to 500A limits, else bms will debate the drive performance?
Thanks in advance.
Re: Simp BMS
alexbeatle wrote: Wed Sep 18, 2024 6:19 am else bms will debate the drive performance
this depends on how you wired it up and configured any CAN to the SDU.
alexbeatle
Re: Simp BMS
tom91 wrote: Wed Sep 18, 2024 7:21 am this depends on how you wired it up and configured any CAN to the SDU.
No CAN to SDU from BMS. SDU controls the HV contactors and pre charge. BMS only allows SDU ignition to turn on if batteries are ok (but doesn't turn it off) and enabled/disable drive mode and charge mode.
I thought SimpBMS charge and discharge limits will control the Tesla modules satellite boards to debate on the module.
Re: Simp BMS
alexbeatle wrote: Wed Sep 18, 2024 3:32 pm thought SimpBMS charge and discharge limits will control the Tesla modules satellite boards to debate on the module.
?!? what are you on about explain yourself please. There seems to be a big mis interpretation of how a BMS works.
alexbeatle
Re: Simp BMS
tom91 wrote: Wed Sep 18, 2024 5:43 pm ?!? what are you on about explain yourself please. There seems to be a big mis interpretation of how a BMS works.
Good thing I asked.
Do you mean that the satellite boards on the battery modules only collect data, but don't actually control the battery module - ex. don't allow current above xA?
Re: Simp BMS
No BMS has a method for limiting current. It can only cut off the current using the contactors.
A BMS monitors and gathers data then decides on limits and share this with the vehicle. (Balancing is the only thing it can do on its own of it does not have contactors)
alexbeatle
Re: Simp BMS
tom91 wrote: Wed Sep 18, 2024 6:26 pm No BMS has a method for limiting current. It can only cut off the current using the contactors.
I see now. Thanks for your patience! That is a fundamental that I was missing.
nedim
Has thanked: 4 times
Re: Simp BMS
Post by nedim »
I try to connect Teensy board with Tesla Module with Rx/TX but not recognized it, BMW works fine with transceiver. Question is are the pins 3 & 4 for Tx and RX on Teensy board for Tesla Module.
Cheers
Re: Simp BMS
nedim wrote: Wed Oct 09, 2024 2:04 pm I try to connect Teensy board with Tesla Module with Rx/TX but not recognized it, BMW works fine with transceiver. Question is are the pins 3 & 4 for Tx and RX on Teensy board for Tesla Module.
Cheers
What are you on about? You wired power to the Tesla slaves?
https://github.com/Tom-evnut/TeslaBMSV2 ... aBMSV2.ino
#define SERIALBMS  Serial3
SERIALBMS.begin(612500); //Tesla serial bus
nedim
Re: Simp BMS
Post by nedim »
tom91 wrote: Wed Oct 09, 2024 4:12 pm What are you on about? You wired power to the Tesla slaves?
of course, and I connected Slave Rx/TX direct to Teensy pin 3&4
Re: Simp BMS
tom91 wrote: Wed Oct 09, 2024 4:12 pm #define SERIALBMS Serial3
https://www.pjrc.com/teensy/td_uart.html
Also note you need to have the 5V ground also to the teensy ground.
nedim
Re: Simp BMS
Post by nedim »
tom91 wrote: Wed Oct 09, 2024 5:12 pm https://www.pjrc.com/teensy/td_uart.html
tnx gnd was a problem now regonise it
alexbeatle
Re: Simp BMS
Hi, there.
Could you please help me understand. I don't quite see why my discharge current gets derated. I have max discharge set to 150A, but this morning BMS derated it to 30A. I didn't capture it at 30A, but below is the screenshot showing it at 113A as it seems to be slowly rising as I'm charging.
It's a cold morning, but the batteries where at 10C...11C temperature, when it derated the current to 30A. SOC was at 24%.
My understanding other than setting it to 0A, this is the only place in the code where the discharge current gets modified:
    //Modifying discharge current///
    if (discurrent > 0)
      //Temperature based///
      if (bms.getHighTemperature() > settings.DisTSetpoint)
        discurrent = discurrent - map(bms.getHighTemperature(), settings.DisTSetpoint, settings.OverTSetpoint, 0, settings.discurrentmax);
      //Voltagee based///
      if (bms.getLowCellVolt() < (settings.DischVsetpoint + settings.DisTaper))
        discurrent = discurrent - map(bms.getLowCellVolt(), settings.DischVsetpoint, (settings.DischVsetpoint + settings.DisTaper), settings.discurrentmax, 0);
However, looking at the snapshot of my battery cell volts and temperature, it looks as though it wouldn't fall within these conditions.
I'm on a forked firmware 230719, but the fork changes are related to the CAN messaging, and relay control.
Please let me know if I'm not seeing the obvious.
Re: Simp BMS
Literally here.
Your settings:
settings.DischVsetpoint = 3200mV
settings.DisTaper = 300mV
So if your cells are below 3500mV limit discharge.
The settings for Discharge Hysterisis is for allowing discharge again when the cells have risen by 200mV (your setting) from Discharge limit setpoint.
alexbeatle
Re: Simp BMS
tom91 wrote: Wed Oct 23, 2024 5:06 pm
Literally here.
Your settings:
Looks like my coffee didn't slap me hard enough this morning to wake me up. Thanks for doing that instead, Tom :D
3500mV translates to 42% SOC per my setpoints (3100mV=10%, 4100mV=90%). I'm curious, do commercial vehicles start to derate at 42% SOC or my setting are too conservative?
X19e
Re: Simp BMS
Post by X19e »
At the moment I'm configuring my Hyper9 system with the SME AC-X1 controller in combination with SimpBMS. They should exchange data via CAN network, but the configuration page of the TAU smartview software causes me problems.
I'm running TESLABMSV2.ino and this is the CAN output: Image
The TAU software configuration page looks like this: Image
It looks like they expect BMS status and SoC, Limit and Current values in different Bytes of the same ID. How do I configure this in SimpBMS?
Best regards
Frank
Re: Simp BMS
X19e wrote: Sun Oct 27, 2024 3:18 pm How do I configure this in SimpBMS
Not possible. You need to modify the code to add this message structure.
X19e
Re: Simp BMS
Post by X19e »
tom91 wrote: Sun Oct 27, 2024 3:58 pm Not possible. You need to modify the code to add this message structure.
OK. Is it easier to add a new ID with this structure or modify one of the existing?
I do have an Elcon charger and DC/DC converter on the same Canbus. So I shouldn't interfere those communications.
Best regards
Frank
Re: Simp BMS
X19e wrote: Sun Oct 27, 2024 4:20 pm Is it easier to add a new ID with this structure or modify one of the existing?
You need to change code so up to you how you do it.
X19e
Re: Simp BMS
Post by X19e »
tom91 wrote: Sun Oct 27, 2024 4:31 pm You need to change code so up to you how you do it.
You are right, if I want to do that, it is my responsibility.
Based on the code, the VEcan() function was added primary for the Victron Energy support and maybe that's why so many ID's are in use.
A Charger is enable via CAN broadcast message. Don't see any message for the DC/DC, maybe have to add it too.
My charger has a separate 12V/5A output that I've connected to the 12V Battery. The idea is to keep the DC/DC switched off during charging to save additional load.
Kind regards
Frank
